Results 1 to 6 of 6
how to grind bolt head to proper diameter?
    Dec 2003
    Framingham, MA
    BACKGROUND (not necessary to know):
    My bike's an '88 EX500.
    On the back half of the left handlebar's control housing is a tab that plugs into a hole in the handlebar. This keeps the control housing from rotating. The tab has broken off and I need to replace it to keep the housing stationary.
    I'm going to insert a bolt into the housing where the tab used to be. The bolt's head will plug into the hole on the handlebar. The hole is about 3mm in diameter.
    I haven't been able to find a bolt with the proper-sized head diameter (it needs to be accurate or this repair won't work). I'm going to use a mild steel hex-head bolt... but the head of the bolt I'm going to use is just slightly larger than the hole. I need to grind it down about 0.5mm in diameter.
    MY QUESTION (finally):
    How can I grind the head of a mild steel hex-head bolt down about 0.5mm in diameter? (Or, if you read the above, do you have any other advice?)
    Thanks!
    '88 Kawasaki EX500
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    bench grinder or right angle grinder or dremel????
    or am i misunderstanding the complexity of the problem?
    Dec 2003
    Framingham, MA
    Hmm... I was afraid you'd say that! I don't have any experience with those machines. I was hoping for a more low-tech way to do it. Do you think a metal file would work? Or would that be too slow?
    '88 Kawasaki EX500
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    file would work
    takes a long time if you can fit im not sure wtf your talking bout
    i think a bench grinders what your looking for or ask i think i might have what your looking for in my invatory of parts
    www.bostonmoto.com
    Forum Rules
    Northshore/Beverly, MA
    you need a 1/2 of a mm?
    Dude, that's only .020" in diameter..do you mean 5mm? >.1969?
    And yes I have the grinder to do it...you just gotta get it to me with the correct dimensions...
    Mar 2002
    Amherst, NH
    after the holidays give me a shout, i could stop by with my dremel and tap set?
    it sounds like the problem could be solved pretty easily wth the right tool.
  1. Shims to swap ? Kawasaki/Suzuki/Honda 7.48mm diameter
    By scootertrash in forum Bike Maintenance
    Last Post: 11-07-17, 04:24 PM
  2. Tire math.... can it be used to accurately calculate rolling diameter?
    Last Post: 05-30-16, 08:15 PM
  3. zx6 head bolt torque
    By zgr in forum Bike Maintenance
    Last Post: 07-20-10, 06:39 AM
