Results 1 to 25 of 47
H4 bulbs --> H7
    H4 bulbs --> H7
    so I bought a new headlight for the gixxer over the winter. my original headlight assembly (and wire harness) used H4 bulbs. my new headlight assembly uses H7 for some reason.
    H4 - old headlight
    Attachment 19478
    H7 - new headlight
    Attachment 19479
    comparision
    Attachment 19480
    my bike's wire harness has the 3 prongs for an H4 bulb. The H7 uses only 2 prongs, but will physically fit in the plug. The H7 will only light up on hi-beam, which makes me believe that the 3rd prong on the H4 harness is used for low-beam ground.
    Any ideas how I can get this to work? I have a feeling i'll need to but off my H4 harness plug & solder on an H7 plug.
    Re: H4 bulbs --> H7
    Isnt the H7 a single filament bulb? I'm thinking this may require an additional bulb for low beam.
    Re: H4 bulbs --> H7
    i'm not finding much online. just saw one website say that either would fit on mine (02 GSXR 600)
    who knows
    Re: H4 bulbs --> H7
    You could just get a set of those DDM HID's with an H7 bulbs then you'd be all set?
    Savannah, GA
    Re: H4 bulbs --> H7
    i believe you can get a socket for a headlight bulb from a regular auto parts store. Put the bulb in that fits and then get the socket to fit and wire it up.
    Re: H4 bulbs --> H7
    already ordered replacement H7 bulbs. was running PIAA Xtreme White 55w bulbs in H4. ordered the same for the new H7 headlight assembly
    Re: H4 bulbs --> H7
    The problem is, if the H7 is a single filament bulb it simply can't work as both hi and low beam. I believe this is going to end up being an "either or" situation.
    Remember, hi beams have the reflectors near the filaments. If the bulb doesn't have that then, IMO, you have your answer.
    Savannah, GA
    Re: H4 bulbs --> H7
    Or, you can trim an h4 bulb to an h7. saw a thread on sportbikes.net
    Re: H4 bulbs --> H7
    Quote Originally Posted by The Magician View Post
    Or, you can trim an h7 bulb to an h4.. saw a thread on sportbikes.net
    so is there an adapter? it's not a fitment issue, as my new headlight assembly will only fit H7 bulbs. it's more of getting the 2 prong H7 bulbs to work on low & hi beams on the H4 harness
    Savannah, GA
    Re: H4 bulbs --> H7
    Quote Originally Posted by DBKromz View Post
    sorry. H4 is dual filament. H7 is single filament. H4 is bigger than H7, so make an outline of the H7 bulb... get an H4... trim the H4 to fit. That way you can use your old wiring, keep the dual filament.
    Make sense?
    Re: H4 bulbs --> H7
    Make sense?
    yes it does. so cut my H4 bulbs to fit the H7 headlight assembly. kind of a PITA, but do-able. thanks. looks like i'll have to RMA my H7 bulbs I just ordered.
    who knows
    Re: H4 bulbs --> H7
    doh...
    This seems like a viable option but you're going to have to be really carefull especially if you grind the metal away. I'd say you do this but use some nice and sharp metal snips and use a lot of releaf cuts so the metal doesn't curl up and scratch the bulb
    Savannah, GA
    Re: H4 bulbs --> H7
    Pain, yeah.. but it's easy enough to do and for as often as you will replace bulbs, not a big deal. At least you will get the functionality you want. I'd need to look at the units up close, but maybe there's a way to remove the mounting rings from your old light and get them to fit the new headlight assembly too.
    Re: H4 bulbs --> H7
    i looked on my H4 bulbs, and it looks like they soldered or made some type of connection from the ring to the light. that was the 1st thing i thought of
    Savannah, GA
    Re: H4 bulbs --> H7
    I'd just trim the H4's to fit. There may have been a change with the headlight you are now using as to the high/low configuration within the electronics. Some bikes use both bulbs for high/low. Some use one high, one low. Pending switch position, it will move power accordingly. If you stick to what you had, you wont need to worry about it.
    Re: H4 bulbs --> H7
    i'm wondering if it's going to mess anything up with the reflection on this new headlight assembly, that's designed for H7 bulbs
    rrrright down by da beach island boyeee's Avatar
    Quincy, MA
    Re: H4 bulbs --> H7
    i'll do the trimming while you swap my brake stuff
    08 Triumph Daytona 675, Jet Black w/ Gold
    dirty bike: 2015 KTM 250 XC-F
    Savannah, GA
    Re: H4 bulbs --> H7
    Don't know til you try... as long as the guts look the same, they will reflect light the same way I'm sure.
    Re: H4 bulbs --> H7
    thanks for your help
    Just Registered drop's Avatar
    Bradford, MA
    Re: H4 bulbs --> H7
    swapping H4 for H7 will almost certainly cause lens/refraction issues. the H7 headlight assembly is designed with non-symmetric reflectors that are designed to output a low beam pattern on one side and a high beam pattern on the other.
    running both with H4's will produce at best the following:
    headlight switch set to low beam
    one normal low beam
    one slightly dim high beam
    headlight switch set to high beam
    one extra bright low beam
    one normal high beam
    taking into account the slightly offset nature of dual filament bulbs and the internal shields they use to direct light, it will likely produce worse results than above. if you want to see how badly a slight misalignment of the filament will mangle your beam pattern, try taking the spring clip off the back of a correctly installed H4 or H7 and watch what very small movements do to the pattern you see on the ground.
    - Jamie
    2009 K 1300 S
    Re: H4 bulbs --> H7
    Quote Originally Posted by drop View Post
    one normal low beam
    I tried to tell you, Jim.
    Lifer Kenn157's Avatar
    Saddlebrooke AZ
    Re: H4 bulbs --> H7
    Thats what I have now. PIAA
    Southington, CT
    Re: H4 bulbs --> H7
    FYI.. 01 and 02 600's (maybe 03's) used one side for low, and the other for high. When on low, one side is off. They use the H7 bulbs and rely on the left (looking at it from the front of the headlight) for highbeam, while the low stays on...
    I have an 03 750... it has dual H4's, so both sides are on, regardless of high or low. It IS a different housing, even though physically it looks the same as any other 01-03 600...
    Unfortunately your gonna be blinding the shit out of people with one side of the headlight assembly because its setup to reflect higher... Its a popular mod for people with the 01/02/(03?) 600s to upgrade to the 02/03 750 housing (not sure about the 01 750s) for the dual filiment bulb setup.
    Re: H4 bulbs --> H7
    so i probably have a 750 assembly & wire harness plugs on my 600. makes sense.
    the new assembly i got will only fit H7 bulbs, and the old assembly i have will only fit H4 bulbs
    Re: H4 bulbs --> H7
    Sylvania SilverStar Ultras FTW! (Yeah, they're $50 a pair, but well worth it.)
    BTW, the 06/07 CBR1000RR uses adapters that are installed on the bulbs to connect to an H4 style plug. (Honda must be cheap, using the same connectors for both H4 and H7 fixtures.) Part number is 33130-MAT-611 [part 6 in the below pic] and available online from Zanotti Honda for under $10 (plus shipping).
    The Ultra bulbs are super-bright. In fact, with my car, people keep flashing me to turn my high beams off, even when I'm using only the low beams.
  1. 1157 led bulbs
    By Kazinator in forum Bike Maintenance
    Last Post: 08-08-11, 12:05 PM
  2. Headlight bulbs....
    By marshdrummer in forum General Bike Related
    Last Post: 04-17-07, 11:00 AM
  3. FS: two 9007 HID kit bulbs
    By 13 in forum For Sale
    Last Post: 03-27-07, 06:00 PM
  4. headlight bulbs
    Last Post: 05-17-06, 06:30 PM
  5. New Headlight Bulbs
    By ZX-12R in forum General Bike Related
    Last Post: 07-20-05, 07:59 AM
