Results 1 to 2 of 2
handlebar angle and height adjustments
    Senior Member kumpy's Avatar
    May 2012
    Norton MA
    Got a 2000 R6 and I have aftermarket Woodcraft clip-ons. Anyone know the correct angle and height it should be? Is this a personal preference thing or are there exact degrees and height I should set them at? I have my clip ons about 2mm apart from the upper triple tree, but I'm not sure if it should be flush up against the triple. Then what I did was I visually adjusted the steering wheel as straight as I could make it. Then I measured the end of each side handlebars and make them both 7 3/4 inches from the exact same spot on each side of the frame. Does this sound like a good method or is there a more precise accurate and proper procedure in doing this?
    Re: handlebar angle and height adjustments
    Whatever's comfortable.
  1. rearset - height adjustments
    By Marc R in forum General Track Day Talk
    Last Post: 09-06-12, 08:31 PM
  2. 2000 R6 throttle adjustments?
    By kumpy in forum Bike Maintenance
    Last Post: 07-01-12, 06:57 PM
  3. EVR Stack height?
    By clutch in forum General Bike Related
    Last Post: 04-08-11, 06:13 PM
  4. Handlebar height suggestions?
    By gamorg02 in forum Dirty Bastards
    Last Post: 06-21-10, 02:18 PM
  5. 98 CBR 900 RR seat height
    Last Post: 03-03-03, 07:51 PM
