Got a 2000 R6 and I have aftermarket Woodcraft clip-ons. Anyone know the correct angle and height it should be? Is this a personal preference thing or are there exact degrees and height I should set them at? I have my clip ons about 2mm apart from the upper triple tree, but I'm not sure if it should be flush up against the triple. Then what I did was I visually adjusted the steering wheel as straight as I could make it. Then I measured the end of each side handlebars and make them both 7 3/4 inches from the exact same spot on each side of the frame. Does this sound like a good method or is there a more precise accurate and proper procedure in doing this?
