Page 12 of 19 FirstFirst ... 2345678910111213141516171819 LastLast
Results 276 to 300 of 452
Harbor Freight tools that DON'T suck
  1. #276
    Feb 2008
    Rhody
    Re: Harbor Freight tools that DON'T suck
    Quote Originally Posted by Vovchandr View Post
    Dewalt has a multi tool system where you keep the cordless body but you can swap different chucks onto it. For me the oscilating head and the ratchet are 2 for one special and work great and save room.
    Very happy with this setup (12v body shown but I have the 18v and also a corded body)
    Oooh, that looks very convenient.
    Hyper
  2. #277
    I just realized I said Dewalt in my post. It is Ridgid!
    Feb 2008
    Rhody
    Well, I'm married to DeWalt and can't afford that divorce so I guess I'm out of luck.
    Hyper
  4. #279
    Not quite
    Got $21?
    https://www.amazon.com/Adapter-Conve...706556&sr=8-12
    Harbor Freight tools that DON'T suck-71zsn35rxfl-_ac_sl1500_-jpg
    Harbor Freight tools that DON'T suck-71rpykr33hl-_ac_sl1500_-jpg
    Feb 2008
    Rhody
    Not quite
    Got $21?
    Let me ask my wife
    Hyper
  6. #281
    holland ma.
    I haven't used one of those. What do you use it for the most? Or is it really just a great multi-use tool?
    I find it best for doing fine plunge cuts to things. Like cutting a hole for an outlet or finishing cuts that the circular saw just couldn't quite reach like corners and stuff.
    It's pretty handy to just have around and small enough to stuff in a drawer. It's pretty good with a metal cutting blade but is only for thin stuff.
    I don't remember which brands this impacts, but I can look it up if need be. Some brands put the low-voltage cutoff circuit in the tool, whereas some put it in the battery. So there's a chance that, with the wrong combination of brands, you can use a battery in someone else's tool and ruin the battery by draining it 100%. Just something to be on the lookout for
  8. #283
    Lifer gixxer72's Avatar
    The desert
    https://www.harborfreight.com/15-amp...der-57363.html
    I normally run $1,700 pneumatic grinders in my shop. On a whim we brought in the linked grinder. They are legit, and dirt cheap. I’ve since put a dozen of them in the shop with zero failures or issues. If you’re a weekend warrior fabricator (or pro) they might be worth your consideration.
    Attached Thumbnails Attached Thumbnails Harbor Freight tools that DON'T suck-13fd73d1-f500-4364-a2c0-3c00a2f6ada5
    Lifer OneCheekRider's Avatar
    Aug 2012
    LA
    HF must have read this thread, looks like I'm headed there today...
    Harbor Freight tools that DON'T suck-angle-grinder-jpg
    You should get HF grinding discs and fancy Home Depot discs and compare the performance. I wonder if that's where the money is better spent?
  11. #286
    holland ma.
    DeWalt disks work way, way better than the hf stuff. Like way better. Same goes for saw blades.
    I have the harbor freight one (well 2 of them).
    I cut metal pipers, sharpen mower blades, grind down stuff.
    I think $14.99 when they go on sale. 8+ year on my old one.
    Edit: $10 with the coupon is a no brainer
    These are what you want for grinding down
    S SATC 20 Pack Flap Discs 40/60/80/120 Grit Grinding Wheel 4.5" x 7/8" High Density Bevel Type Angle Grinder Sanding Disc Abrasive Grinding Disc #29 https://a.co/d/5ACi35o
    Bought the Titanium MIG 170 welder, I’ll keep you posted.
    The HF motorcycle lift is now $600!
    if you catch the sale right, you'll get it for $499. i've seen it for that price reciently.
    i got mine for $485 about 4-5 years ago and havent seen it cheaper since.
    i bought this when it was that price too. crazy that i use it a lot more than planned. makes chain replacement much easier.
  16. #291
    Anyone have this power washer? Have been wanting something to wash bicycles and stuff around the house and there's a coupon for it.
    https://www.harborfreight.com/1750-p...BALANCE&plcc=N
    We have a DeWalt gas pressure washer with a real Honda motor. They are rebranded Simpsons. The pump failed when ai was taking the boat out. So we bought a Predator model similar to the DeWalt.
    If I had a do-over I’d go straight to the HF model. Works just as well, and seems less sensitive to freezing - which is why the Simpson/ DeWalt probably failed.
    3200 PSI, 2.8 GPM, 6.8 HP
    Performance is fine. But it’s junk. It doesn’t last.
    Thanks for the info sav! I'll pass.
    For a little more I've been using the SunJoe amazon model for a number of years now around the house. VERY useful tool to have on hand. Not AS strong as gas powered, but strong enough to do all the home chores and needs AND never have to mess with another carburetor or have it be stupid loud.
    Whatever model you pick strongly recommend having a hose reel on it for the pressure hose AND having an extra 10 or 15 ft whatever hose extension.
    Should have elaborated. I’m not really against it.
    It goes on sale for $79.99 and $69.99. I think you can get a warranty for $30 for 3 years. The warranty will really cover it.
    If you don’t mind driving to HF every few months to replace it get one. If your closest HF is too far maybe not worth it.
    I have one on my way to work so I legit treat them like they are disposable. 2 replacements this summer and no issues at all. I use it A LOT.
    New Haven-ish, CT
    Bought it a couple months ago to primarily wash the cars and the dirtbike. Used it a couple times so far, works fine. Doesn’t take up much space in the garage. Also used it to clean a vinyl fence. Didn’t need the power of a gas one or the maintenance.
    HF also sells a wand for it that allows you to use standard quick-connect pressure washer tips
    https://www.harborfreight.com/quick-...and-57580.html
    Owned two different electric pressure washers. Neither lasted more than a few seasons. Karcher and another brand. The good, durable electrics are as expensive as gas washers.
    Thry have their advantages as well: no noise, smaller to store, don’t have enough power to damage most things.
    Jamnuts jhawley's Avatar
    Oct 2009
    Southern CT
    I didnt know this even existed.
    Hypertarded
    RI / CT border
    SunJoe on sale at Amazon $94
    https://www.amazon.com/Sun-Joe-press...DKIKX0DER&th=1
    Don't forget this to keep it running
  1. Harbor Freight Tools road trip.
    Last Post: 04-06-10, 07:46 AM
  2. Harbor Freight Tools
    By 2OO6rr in forum Business & Product Reviews
    Last Post: 06-21-09, 10:34 AM
