Results 1 to 4 of 4
Help: New-to-me 09 Honda Shadow Aero
    Senior Member SCRLT01's Avatar
    Oct 2010
    Westford, MA
    My brother was just deployed, and is letting me use his bike for the year. He's horrible with maintenance/repairs/etc didn't winterize it...
    The thing runs, and I put new gas in it...however it loses power (doesn't matter what I'm doing - inclines, accel/decel). The general consensus of folks I've asked is that its a "fuel issue". Does anyone have time to help me figure this out, or can recommend a reliable shop (that won't gouge me cause I'm a chick) to have this looked at (and give it a general once over)?
    Located in Westford, MA...
    --Jesse
    2001 SV650s
    Re: Help: New-to-me 09 Honda Shadow Aero
    Check tank for rust first. If the tank is rusty, you will need to have it treated and coated, otherwise fuel issues will keep occurring. Is the bike carbed or EFI? In the former case you may have to go through carbs and clean them. In the latter case you will need to check fuel pressure. You may need fuel injectors cleaned or replaced and possibly fuel pump (the pumps don't like rust).
    Dic on
    Remember, most of your fuel is actually air. If you have a mouse nest in your airbox, you will likely have a blocked air filter and that will literally choke the motor and produce your symptoms. Easy to check.
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    "Too bad ponies are assholes."
    OXX
    Lifer golden chicken's Avatar
    Fitchburg, MA
    How is it we are just now seeing this thread, 3 months after it was supposedly posted?
