Results 1 to 20 of 20
Help! 09 Zx6r
    Lifer Danz19899's Avatar
    Grafton, Ma
    Help! 09 Zx6r
    Ok well I just started getting my bike ready for the track this weekend.
    I am putting track plastics on, engine covers, oil coolant & coolant change.
    I'm half-way through and now my bike wont run. It will start and run for 2 seconds then dies and iI get an FI light. went back over my work cant figure what io F**ked up for the life of me. I did the oil change and am trying to run it to finish the coolant change. Also attempted to swap the stator cover but stripped one of the bolts holding the stator on so i just put it back on.
    Any Ideas??
    went as far a plugging my entire front cowl back in but still nothing.
    BTW 09 ZX-6r 11,000 miles pretty much stock till now
    www.bostonmoto.com
    Ride to live, live to ride
    Lancaster
    Re: Help! 09 Zx6r
    i know on my bike when i got the FI light i could trace to what it is by the blinks, look in the owners or service manual to see how its done
    Corey
    Re: Help! 09 Zx6r
    FI light is coming on because the ECU knows the engine isn't running. Don't sweat that one.
    The engine covers aren't the issue and neither is the oil or coolant.
    Do you know if the tip over sensor is located in that front fairing section? If it is and the fairing isn't correctly oriented, that would likely be your issue. I would consider mock-mounting the fairing and proceed from there.
    Grafton, Ma
    Re: Help! 09 Zx6r
    the only thing on my front other then lights is my rectifier which i have unbolted and its just kinda hanging there, gonna try and figure out where the tip sensor is on google
    www.bostonmoto.com
    Re: Help! 09 Zx6r
    Double check any an all connectors for everything you unplugged. I know Kawasaki likes to use multiple plugs of the same kind but for different components and it can be a guessing game as to which one goes where.
    Grafton, Ma
    Re: Help! 09 Zx6r
    Ya i was getting tired and frustrated so i just set the tools down and left before i broke something lol
    random but i did take the radiator of to change coolant, maybe something around there lol
    It does kinda sound like the tip sensor tho since it starts and runs fine even time i fire it up but i have to turn th key off and on to get it again
    www.bostonmoto.com
    Grafton, Ma
    Re: Help! 09 Zx6r
    and the FI code this is pretty much just steady blinking no noticable pattern
    www.bostonmoto.com
    Re: Help! 09 Zx6r
    I am not familiar with the particulars regarding this model but do you know if either the oil or cooling systems have to sense pressurization? As in, it won't run unless everything is capped. There are machines out there that need everything closed up in order to run.
    Temp sensor is plugged in and the plug isn't being jumped by anything?
    Fuel pump is priming?
    Perhaps try clicking the gearbox into a gear and then back to neutral. Thinking that the shift drum is contacting the safety switch but the bike thinks the kickstand is down? It's a long shot, I know.
    EDIT: I'm signing off and going home. I wish you luck.
    High maintenance priss
    Central MA
    Re: Help! 09 Zx6r
    I'd doubt ToS if the bike runs. A ToS fault will prevent bike from starting (or any other safety switch like clutch or kickstand, for that matter).
    You said you did engine covers. Could there possibly be a problem w/ the stator since it is bolted up to the inside of the LH cover (question for others, not necessarily Danz). Because stator only outputs AC to R/R, I'd kind of doubt it would kill the bike once bike is running. But maybe someone can chime in.
    Danz - Will it always start up and then just die after 2 sec? Or did it just do that once now nothing?
    Nov 2008
    Framingham, MA
    Re: Help! 09 Zx6r
    I am not sure if you did an exhaust flapper mod ( common with the CBRs). In any event, as far as the CBR is concerned if you remove the exhaust flapper servo the engine light goes on. The work around for this if you so desire to do the exhaust flapper mod (in the CBR at least) is to remove the flapper cable and leave the servo on.
    On another note, I believe a read somewhere that the new ZX6R has an ignition chip on the key. Perhaps, you unplugged the battery and triggered the ignition programming to reset. However, I think you did say that the fuel injection light went on, so that might not be it.
    Go to the Kawasaki website and post your inquiry there.
    Nov 2008
    Framingham, MA
    Re: Help! 09 Zx6r
    On another note, when are you leaving for the BOMO event this weekend? Any chance you have room in your trailer for another bike?
    Try to not be offended DocCola's Avatar
    Everywhere, USA
    Re: Help! 09 Zx6r
    Quote Originally Posted by Eddie View Post
    Are you asking Dan Z? We're taking my truck/trailer up. Don't think we could fit a 3rd bike on. If we did it would be very tight and we would lose room for gear...PM me and him I guess.
    Ajay
    My Facebook-add me
    "The things in life you regret are the risks you never took"
    ....There is nothing but love and tent pitching at the BoMo days....
    Grafton, Ma
    Re: Help! 09 Zx6r
    Ya our truck is pretty jam packed already
    Ok it will start run for 2 seconds then die, in order to start it again i have to turn it off and back on. thats y im thinking TOS cause it resets when its turned off.
    something is cutting fuel or spark
    www.bostonmoto.com
    Re: Help! 09 Zx6r
    kickstand switch?
    Grafton, Ma
    Re: Help! 09 Zx6r
    Quote Originally Posted by Jimmy 2 Shots View Post
    kickstand switch?
    the bike is in neutral with the kickstand up didn't think that would affect it
    www.bostonmoto.com
    Re: Help! 09 Zx6r
    Switch could be sticky.
    Good call Jim.
    Grafton, Ma
    Re: Help! 09 Zx6r
    Got it! It was the damn TOS i unplugged it on accident, i was also looking for it at wrong end of the bike lol its at the very end of my subframe i was looking around the radiator
    come on bergs u actually thought Jim got something right?
    www.bostonmoto.com
    Re: Help! 09 Zx6r
    Well, at least it was the tip over sensor and not some other crazy thing. Glad you got it sorted.
    Re: Help! 09 Zx6r
    Quote Originally Posted by Danz19899 View Post
    Austin, Tx
    Re: Help! 09 Zx6r
    Dan,
    I'm way late on this thread, but since we have/had the same bike, I'm hoping you can help.
    I'm mounting race bodywork on my bike, and I'm having trouble clearing the rear tray that the tip over sensor mounts to. This is the piece that I mean: http://www.ebay.com/itm/KAWASAKI-ZX6...-/251096393607
    Did you remove this when mounting your bodywork? If so, wear do you mount the ToS on the bike? If not, did you have to remove material from the tail? I'm using HotBodies bodywork, if it makes any difference.
    Thanks,
    Jon
    '14 Aprilia Tuono - crack on 2 wheels, '14 Ninja 300, '04 BMW M3
  1. 96 zx6r
    By pcakes55 in forum For Sale
    Last Post: 08-06-11, 04:55 PM
  2. Replies: 0
    Last Post: 04-09-11, 01:50 PM
  3. Replies: 2
    Last Post: 04-17-08, 10:40 AM
  4. 07 ZX6R
    Last Post: 08-18-07, 11:30 AM
  5. ONLINE SERVICE MANUAL!!! 00-02 zx6r, 03-04 zx6r(rr?)
    Last Post: 06-20-04, 11:01 AM
