Results 1 to 20 of 20
Need ideas removing clutch lever (the nut it swings on)
    Lifer isaac_'s Avatar
    Jul 2014
    Central CT
    And i'm not talking about me!
    Need to switch clutch levers today because the one on there is busted. And I've got TTD tomorrow...
    The nut just spins and spins. It doesn't want to catch on a thread for it to back out... Any thoughts on how to remove it that don't require 3-5 hands? I'm hoping to do this before I show up to Thompson tonight. Or does anyone have a second gen sv clutch perch or whatever it is that the clutch lever attached to is called?
    Need ideas removing clutch lever (the nut it swings on)-118e8866af675d4d4a3941e8b44f86dc-jpg
    Re: Need ideas removing clutch lever (the nut it swings on)
    So the bolt is stripped? I would use my third hand to apply as much pressure as possible to the end of the bolt while using my other two hands to try to get it to catch the threads.
    Jul 2014
    Central CT
    I don't think it's the bolt. The NUT (and I think it's one of those that has a nylon on it) doesn't seem to want to grab the bolt. I think I overtightened when I put this on. Mind you I have no way if the bolt itself is stripped.
    I rarely see nuts strip... (??) Either way, my three handed technique should work. LMAO
    Jul 2014
    Central CT
    Ok.. That's funny Need ideas removing clutch lever (the nut it swings on)
    High maintenance priss
    Central MA
    If it spins (I'm assuming you're holding the nut w/ a wrench), then it's stripped. I would just cut the sucker off using a dremel w/ a cutting disc. You might be able to salvage the bolt depending on which part is stripped.
    If you need to borrow a perch & lever assembly, I do have at least a couple laying around for other brand bikes but should work fine.
    Access looks tight, but I would also cut with a dremel. I don't know how racing even existed before the dremel...
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Do you have an air gun? If yes, try that, if no...
    What does the "other side" look like? Can you grind the head off the other side?
    Mar 2012
    Chichester, NH
    Because die grinders.
    Jul 2014
    Central CT
    Sigh. I didn't want to have to cut. But I think it's the only way to go...
    luckily there's a hardware store that usually carries hard to find nuts and bolts. I'll swing by. That or cyclegear. Every once in a while I luck out there.
    Buy a set of pro-tec nuts bolts specific to the SV, or just any dirtbike. Best money spent on a race program. Can't be slowed down by a little dremelling.
    Jul 2014
    Central CT
    These things?
    PROTEC - THE CAP COMPANY - Products overview Cable Glands - Caps - Safety rings
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    See. I told you... Lol
    Jul 2014
    Central CT
    Dremel for the win! Bought whatever nut bolt kit I could find at cycle gear.
    Thanks for the...tip? Harrrrrr....
    Nov 2009
    Bristol County
    Was the bolt stripped, but only on the portion under the nut? So the nut's threads wouldn't walk back down the bolt shaft? Don't think I've ever seen that happen before, but there's still time!
    nedirtriders.com
    Jul 2014
    Central CT
    Oh you guys... Can't get enough of this... Humor.
    It was hard to tell because I had to dremel out the nut. But when it was all said and done that's exactly what it looked like. My guess is I over torqued it and just snapped the threads underneath the nut.
    Central MA
    If there's room for another tip...
    What I did was purchase a couple hardware kits from a shop who parts out wrecked bikes. Has proven to be ridiculously useful to have handfuls of OEM fasteners. The place I used was Suncoast Cycle Sports. They are a bit on the expensive side tho. SCCS Ebay store
    sometimes with an air gun, and maybe even an electric, you can get it spinning fast enuf in reverse to unthread itself
    however, very likely the bolt that is buggared up is a special shouldered bolt
    in my SV, I used KLR standoff bolts for my handguards, I may have an original around but doubtful I could put my hands on it
  1. No clutch lever? No shift lever? No footpeg? No problem.
    Last Post: 08-29-11, 01:25 PM
  2. loose clutch lever
    By njsrikar in forum Bike Maintenance
    Last Post: 08-09-09, 07:51 AM
  3. anyone have a clutch lever
    By Truth in forum For Sale
    Last Post: 10-20-08, 08:12 AM
  4. Clutch lever?
    By Honclfibr in forum General Bike Related
    Last Post: 04-08-05, 07:33 AM
  5. Clutch Lever
    By Cowboyrider in forum Bike Maintenance
    Last Post: 09-01-03, 09:31 PM
