Results 1 to 12 of 12
Independent Mechanic
    Senior Member Legion1440's Avatar
    Medford, MA
    Can anyone recommend an independent mechanic, or should I just bring my bike to a dealership. I've had an issue with the bike overheating since last year. I've changed the coolant, pump and thermostat and it still happens. Basically once the bike heats up, it stalls pretty quickly once I get stuck in traffic. I'm at a loss now, so I think I'm better off just bringing it to someone else to deal with.
    Jun 2005
    Re: Independent Mechanic
    Ignition coils?
    Bring it to Degsy?
    Trapped air pocket?
    Check the flow of the water pump?
    2016 BMW S1000XR
    Nov 2009
    Bristol County
    Fan not coming on? Airpocket sounds possible too. Does the bike have a bleeder valve anywhere in the system?
    nedirtriders.com
    Lancaster
    Wirelessly posted
    Degsy
    Corey
    crack the water pump's drain bolt until it starts leaking out coolant. obviously put a pan under there to catch what coolant comes out.
    take the radiator cap off and see if the fluid is topped off. make sure the reservior is about 1/3 full.
    turn the bike on with the cap off.
    Keep it running until the thermostat kicks in. many inline bikes are around 150 degrees Fahrenheit. you'll know when it kicks in when a good portion of the coolant gets sucked down.
    if this happens, top off the fluid again, cap it, and shut the bike off.
    if it never happens, then you have a thermostat issue.
    Lifer Danz19899's Avatar
    Grafton, Ma
    That's never good could be a bad head gasket, open the radiator and if u see constant bubbles you could be getting combustion pressure in ur coolant.
    But it could just be a clogged radiator, fans not working or an air bubbles
    www.bostonmoto.com
    Ride to live, live to ride
    Nov 2004
    Boston, MA
    Wirelessly posted
    Degsy
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Raymond NH
    How hot does it get before it stalls? Is there a temperature gauge that's in the red or alarming in some manner? I'm simply trying to correlate the stalling with overheating.
    Wirelessly posted
    Appreciate the referrals guys but degsys all night discount bike service shop is closed for business. I have a bunch of projects that will be taking up my time and I'm service manager at adrenaline cycle now so it's a bit of a conflict of interest also.
    Wirelessly posted
    Having said that, the first thing you need is a compression test.
    Nov 2004
    Boston, MA
    Wirelessly posted
    Adrenaline cycle
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
  1. For Sale - Other | Independent Fabrications mtb frame
    By bryco13 in forum For Sale
    Last Post: 12-27-14, 07:29 PM
