Results 1 to 23 of 23
How to inflate your tires with WD40
    Member Cambridge K's Avatar
    Cambridge,Ma
    iTrader Score
    0 Not allowed!
    Two things help getting older - BMW'S and Metamucil
    Mar 2004
    woonsocket ri
    iTrader Score
    Re: How to inflate your tires with WD40
    You use ether not WD40. And it doesnt inflate the tire. It just seats it on the rim.
    0 Not allowed!
    iTrader Score
    Quote Originally Posted by dhuze View Post
    original formula wd40 was flamable, but it hasn't been flamable for 20+ years
    0 Not allowed!
    Ense petit placidam sandman's Avatar
    sema
    iTrader Score
    unless they changed the formula in the past 6 months. for the past 20+ years it HAS been very flamable.
    starting fluid works even better on a truck tire, but i must admit iv'e never tried it on a mc tire.
    0 Not allowed!
    jim
    "Molon labe"
    iTrader Score
    Quote Originally Posted by sandman View Post
    it burns, but does not create explosive fumes like ether, the aerosol propelent used to be flamable as well many years ago, it no longer works good as fuel for potato guns
    0 Not allowed!
    Gales Ferry, CT
    iTrader Score
    The Material Data Safety Sheet (MSDS) from the manufacturer lists the flash point as 131 degrees F. That would make it flammable!
    http://www.wd40.com/files/pdf/msds-wd494716385.pdf
    0 Not allowed!
    2008 Triumph Sprint ST ABS
    Cambridge,Ma
    iTrader Score
    Fire lube
    0 Not allowed!
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    iTrader Score
    beans candle then wait
    I use starting fluid myself
    0 Not allowed!
    Glen Beck is John the Baptist
    iTrader Score
    Quote Originally Posted by caddydaddy View Post
    like I said, it burns, it won't ignite from a spark at room temp, unlike ether that has a flash point of about 50 below zero
    years ago, the propelant that WD40 used in it's aerosol product had a low flash point and it could be used as potatoe gun fuel, not anymore
    0 Not allowed!
    Reading
    iTrader Score
    Brake clean/carb clean/starter fluid works better. Hell even hairspray in pinch would do.
    0 Not allowed!
    Junior Member screamingbuick's Avatar
    South Hadley, MA.
    iTrader Score
    I wouldn't use either, right down the street from my house a guy was using ether on a truck tire and static ignited it, the rim took his head right off and proceeded thru the shop roof...i wasn't there but i bet it wasn't a pretty site.
    0 Not allowed!
    F.Y.Y.F.F jcbell1007's Avatar
    Vermont
    iTrader Score
    13 (100%)
    Quote Originally Posted by screamingbuick View Post
    same thing happened to a mechanic in my home town. though he didn't lose his head, he almost lost his leg and 90% of the hearing in is left ear.
    call me a wuss but ether is explosive and I won't be mounting a tire that way.
    0 Not allowed!
    Clutch Brake Throttle.....
    LRRS AM #107
    2008 Hypermotard 1100S -
    Senior Member Pestilence's Avatar
    Salem MA - Soon.. Sandy Eggo CA!!!
    iTrader Score
    If you've ever gone off-roading in BFE and popped a bead, you better have a can of starter fluid and lighter in the glove box or you're in for a shitty afternoon.
    Just remember to remove the valve stem or the tire will implode back in on it self.
    0 Not allowed!
    -John
    "It's more fun to ride a slow bike fast,.. than to ride a fast bike slow."
    07 Husky SM510R
    Littleton, Ma
    iTrader Score
    1 (100%)
    There is no way this happened.
    0 Not allowed!
    Just Registered Doc's Avatar
    Jericho, VT
    iTrader Score
    2 (100%)
    No. The flash point is the lowest point at which a liquid can become ignitable. Thus making it inflamable.
    131 degrees is not as inflamable as gasoline which flash point is something like -30 degrees.
    Edit:
    Sorry... Randy got it.
    0 Not allowed!
    Gales Ferry, CT
    iTrader Score
    Edit:
    No, the flash point is the temperature when the vapors can maintain a flame. The first three words of the "hazards identification" section of the MSDS I provided say "DANGER! Flammable aerosol."
    Just because it won't explode like ether or gasoline doesn't mean it won't flame up with a match!
    0 Not allowed!
    Lifer obsolete's Avatar
    Norf Sho
    iTrader Score
    No flash point means it can ignite but may or may not be able to maintain a flame. That's why it is the "flash" point, because you can get a flash of flame but no burn.
    0 Not allowed!
    -Alex
    Norf Sho
    iTrader Score
    For the record: Inflammable = flammable
    Also I believe the limit for flash point for flammable liquids is 100F, anything above would be combustable to another temp which would determine non-combustable.
    0 Not allowed!
    -Alex
    Aug 2004
    Baltic,CT
    iTrader Score
    Large truck tires have bead rings that are worked on after the tire
    These can and do come off with great violence
    Old milk can
    Calcium Carbide
    good times good times
    0 Not allowed!
    May 2007
    Southern NH
    iTrader Score
    2 (100%)
    Quote Originally Posted by richw View Post
    Old milk can
    Calcium Carbide
    Newer truck don't have the rings anymore. I used to change those and we always used a cage when inflating...
    0 Not allowed!
    "A man who views the world the same at 50 as he did at 20 has wasted 30 years of his life.
    Muhammad Ali.
    KB KB's Avatar
    Manchester NH
    iTrader Score
    2 (100%)
    I love a nice ether explosion, and a nice ether binge.
    0 Not allowed!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Roxbury
    iTrader Score
    Did this with ether to mount 225s on a 10inch wheel back in the day on my jetta....actually really easy to do.
    0 Not allowed!
    Former LRRS EX #978
    Tony's Track Days
  1. Tires???
    Last Post: 08-24-08, 09:04 PM
  2. tires
    By Nikon in forum Dirty Bastards
    Last Post: 07-13-08, 07:11 AM
  3. Tires
    By Nikon in forum General Bike Related
    Last Post: 09-30-06, 06:06 AM
  4. New Tires...
    By Stoneman in forum Off-Topic
    Last Post: 05-09-05, 06:09 AM
  5. tires tires tires free tires
    Last Post: 12-16-03, 10:10 PM
