Results 1 to 19 of 19
Note to self.. don't do that again
    Senior Member LiononaLeash's Avatar
    Oct 2005
    My new ZX-10R specs that you torque the oil filter to 23 ft/lbs on installation. Well... I did that during the last oil change.
    Today I changed the oil and filter(did some drilling and lockwiring while I was in there too). The sucker was stuck on there so good that the oil filter socket dented the flats on the filter(effectively stripping it) when I tried to take it off. I had to drill a hole through the oil filter and turn the filter with a metal rod stuck through it to get it to move.
    I decided to go with about 1/2 the torque spec this time(12 ft/lbs) and I'll be watching it. I thought it was a bit overkill when I put it on the last time, so this was pretty much a confirmation... yah... it was overkill. Don't do that again, you bozo.
    Lifer ZX-12R's Avatar
    Candia, NH
    My calibrated hands tighten it just right every time. Never need a wrench to take it off and it never leaks.
    Make sure to oil the gasket before you install the filter!
    Oct 2005
    Originally posted by ZX-12R
    ...Make sure to oil the gasket before you install the filter!
    yup, as always
    Jun 2005
    That sucks dude. sorry. Im kinda shocked that factory specs gave u a problem. what kinda of torque wrench did u use? The specs on mine are 20 ft pounds and it hasn't givin me any issues.
    Spin on till snug.
    turn another 1/2 turn by hand.
    1 dollar hose clamp & safety wire (optional)
    You'll never have a problem again.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    Hey Bob I hope this makes you feel better
    elaineo did the same thing
    elaineo
    Shut up glow bug
    www.bostonmoto.com
    Forum Rules
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Posting Freak
    New Hampshire
    And prime the filter too!
    KB KB's Avatar
    Manchester NH
    Is that like when I prime my crank??
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Posting Freak
    New Hampshire
    I mean to fill the filter with oil before spinning it on.
    Just that much less time that it takes to build oil pressure when you start it back up.
    May 2005
    Bernardston, MA
    Yeah, every time I've torqued the filter onto my bike, it ends up taking a large screwdriver driven through the side of the filter and a prybar to get it off. And this is with the o-ring oiled and a light coat of anti-sieze on the filter threads.
    1/8 of a liter is plenty SilverDragon's Avatar
    Pittsfield, MA
    That sucks! I'd expect it would be something more like 23 in/lb, because 23 ft/lb is a ton for a filter! I always just do it by hand. Oil the o-ring, then spin it on by hand, then 1/2-3/4 of a turn more by hand. And I've even had problems getting filters off in the past even using this method - i can't imagine torquing it that much!
    Neal Mulcahy
    LRRS/CCS #427 ECK-Racing 2009
    Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Moon Performance | Motorcycles of Manchester | BostonMoto-Pirelli
    yeah!! you sure its not IN/LBS? ive always just put it on hand tight.
    Oct 2005
    Yup, it says Ft/lbs in the manual. Probably a translation issue from Japanese to American.
    I should have listened to that little voice that said "that's crazy" its way too much. The funny thing is there was NO other info about it anywhere I could find. Usually there is installation info on the filter itself too. Spin onuntil contact then turn so much afterward.
    I learned my lesson. We'll see how it goes next spring.
    Candia, NH
    For the 12R it says 19ft/lbs which is still way too much. I had to use channel locks to get the original filter off.
    The tightness you can muster by screwing it down with your hands is plenty, unless you are a girly man.
    Lifer Currently's Avatar
    Ooltewah, TN
    Suzuki does the same thing in their factory service manual.
    I don't listen to it, that is wrong and it is obvious.
    KB KB's Avatar
    Manchester NH
    I usually get a few guys and lift it up!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    23ft/lbs is WAY to much for an oil filter. Hell, the cylinder head bolts on mine are only 25ft/lbs.
    Hand tight. I keep a torque wrench around for the big ticket items where it really matters. Use common sense, and a seat-of-the-pants feeling for everything else.
    Member kmobrien76's Avatar
    Eastern Mass.
    I go hand tight then a little more...
    Kevin
    '05 Warrior
    Quincy, MA
    AIM: BostonianR6
