Results 1 to 10 of 10
K5 tapered front caliper bolts
    Posting Freak
    Dec 2009
    I'd like to shoot the person that thought putting tapered head bolts on K5 front brake calipers was a great idea. I'm sure each PO of this bike flinched every time they removed them. I'm just that last in line and the socket for the hex tool is toast. Even with a new hex socket tool has no chance of getting these out. The inside corners in the head are already rounded. With the tapered bolt head I can't grab it with anything. Drilling it or slotting it is a no go.
    To add insult to injury I had removed the 1st 3 bolts when the last one finally gave up and rounded off. Had a 5/8" bolt tig welded to the socket head of the stuck bolt to get it out. Didn't think to the others were in bad shape so...reinstalled them. Dumb move. Should have replaced them all. I can feel each of them giving a bit at the modest 20lbs of torque as I started installing them again. What a shit design.
    Thought to use the flange bolts from my GSXR1000. They were about 3/4" too long. Bikebandit and other sites typically list the OEM bolt with the same tapered head. The only sites that I see carrying flange head bolts for of the same length seem to be made from titanium, and are likely from questionable ebay sources over seas.
    While I get this latest bolt welded and removed I'd appreciate any suggestions for suitable replacements.K5 tapered front caliper bolts-05-front-caliper-bolt-jpg
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: K5 tapered front caliper bolts
    Lifer golden chicken's Avatar
    Attleboro, MA
    A dab of valve lapping compound on the end of the bit before it strips the bolt has saved me some head/heartache in the past.
    Pro-Bolt USA.
    can even get the stainless pre-drilled ones
    https://www.probolt-usa.com/stainles...c-ssfbmon190r/
    holland ma.
    Pro-Bolt USA.
    Stainless is terrible for those bolts. You only get a few uses out of them before they begin to get suspect.
    A word of caution on those bolts, dont use allen keys with the rounded head. Only use ones that are flat and sit straight in.
    I use titanium for those bolts now. Its a pretty common type of bolt in ti.
    Jun 2005
    Yeah, stainless, despite being pretty is often a poor choice for high-stress bolts. Cruising McMaster shows a regular M8 bolt in 316 stainless has a typical tensile strength of 70,000PSI compared to an alloy steel equivalent at 170,000PSI.
    Oct 2020
    Chelmsford, MA
    So why can't you buy a 10.9 grade bolt that fits?
    1. Measure bolt length.
    2. Determine threading. They're always metric. Probably M8 1.25 but maybe not, so measure twice.
    3. Buy 2 replacement bolts (Amazon, Home Depot, etc.) that meet above, if you are paranoid use grade 12.9. Flanged bolts are nice but you can just use washers.
    interesting. i have the stainless caliper, pad, and fork pinch bolts. never an issue. plus the torque spec is fairly low (16.5 ft/lbs) for pinch bolts
    Dublin, NH
    They're not guaranteed to round off just because they are stainless. It just becomes more likely vs non-stainless if they are torqued improperly, galled, rusted, etc.
    2023 KTM 890 Adventure R
    Jun 2005
    My skydiving rig has a reserve parachute I've never used.
  1. Replies: 2
    Last Post: 06-14-12, 02:18 PM
  2. WTB: 06-07 GSXR Front Rotor Bolts
    By senecak19 in forum Wanted
    Last Post: 09-12-10, 08:03 AM
  3. WTB Front Caliper Suzuki GSXR 600 '01-'03
    By FirstLightning in forum Wanted
    Last Post: 07-03-10, 06:33 PM
  4. WTB 94+ EX500 front caliper
    By Pittenger5 in forum For Sale
    Last Post: 06-26-08, 11:23 AM
  5. radial mount brake caliper bolts?
    Last Post: 07-20-06, 11:14 AM
