Results 1 to 25 of 33
It's a lot easier to solder with flux.
    Your helpful hint of the day.
    Can't believe I ever tried to do it w/o it. Friggin impossible.
    Re: It's a lot easier to solder with flux.
    neither can I. What were you thinking? I would say that anything you soldered without flux is probably a dry joint waiting to happen. Most solder comes pre-fluxed (core flux)
    d
    Eh, what can i say? No one ever taught me how to do it right.
    This time I decided to do some research, first. Woulda been a lot easier if I had more space & wire to work with but I think it came out pretty good.
    You definitely don't want to rely solely on the flux contained in the solder...it's usually not aggressive enough to tin or solder.
    Liquid flux...There's no better choice.
    they didn't have any liquid flux, just the paste stuff. Seemed to work just fine. Liquified instantly once it got hot anyway
    Lifer Jayspeed's Avatar
    Medford, MA.
    I've used core flux solder and either had a good easy solder job or it would be stubborn and ball up rather then seep into the wires.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    Paste is okay but, admittedly, my job has spoiled me with the liquid.
    Maybe a group buy on liquid flux is in order...only $35/ gal...I'm looking at a gallon right now!
    NESR price: $5/ fl oz
    A gallon??? hahaha, I bought a 2 oz tin of paste & I'm sure it'll last me a frikkin LIFETIME!
    So just a 1/2 gallon then??
    Yeah, we go through gallons of this stuff...
    Lifer ZX-12R's Avatar
    Candia, NH
    Also, cleanliness is next to godliness. You want your two surfaces as clean as possible and grease free for a proper solder joint. Agressive fluxes can take care of slightly dirty surfaces but if you have corrosion it should be scraped off mechanically.
    Same rules apply if you are sweating copper pipes and fittings.
    I was just making damn sure that i was getting a good connection since I didn't have a proper crimping tool.
    After seeing that picture... I don't think mine looks quite as pretty any more
    Candia, NH
    $5 * 128oz = $640
    ($640-$35)/$35 *100 = approx 1729% return on investment
    I like your business model!
    Gotta pay for these bikes somehow!
    KB KB's Avatar
    Manchester NH
    Flux is your best friend. I use the plumbing flux paste shit on the wires to. I have had the same can for like 10 years now.
    I heart flux.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Member TimD's Avatar
    Woburn
    That there looks like a terminal for a GM weatherpack connector? Totally worth the $20 investment for the proper crimping tool. I use those things all the time and there totally impractical to assemble without the crimp tool. With the tool they take 2 seconds to assemble and look like that picture every time.
    Tim
    '05 GSXR1000
    Quote Originally Posted by Jayspeed View Post
    :-) wires weren't hot enough.
    But you are
    Aw shit, my name's Pete, not Denno!
    Update... after ALL that FUKKING work... it didn't fix the problem
    Lifer akira700's Avatar
    Apr 2005
    in the city
    bummer man.
    whats up? You got a short circuit in there some where?
    2008 Honda CBR 600RR
    Charging system isn't charging properly. Not getting a full 14 volts at the battery. (getting less than 12)
    I thought it was because I had a fried connector at the reg/rec... common problem.... that's fine... found a different fried connector under the tank... replaced that & no dice.
    Rut-ro...
    Time to grab your favorite multi-meter and ohm out the harness...that'd be my next move.
    yeah I gotta invest in a good digital multi-tester. All I got is one of those cheap little analog ones.
    Dude, Sears Craftsman...I found a decent digital multimeter for like 35 bux.
    Auto range, temp, ohms, continuity, digital display, memory...that's all I can think of at the moment.
    Thing works the balls! Only complaint is the test leads have proven to be a bit on the short side, IMO. An easy fix however.
    yeah, think I saw a couple down at the local hardware store in the 25-30 dollar range when I was there last week... almost picked one up, too. Gonna have to take a closer look at em & see if I can't support the local guys.
    Medford, MA.
    Ya thats probably true. I was probably impatient and was thinking "just gimmi a freakin wirenut!"
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    Candia, NH
    Electrical gremlins are so much fun to find! Did you bring your revs up when you checked the battery voltage? Have you had your battery load tested? A damaged battery can still show 12V.
    In your soon approaching troubleshooting session, you'll end up checking the resistance of the 3 combinations of stator outputs 1-2, 1-3, and 2-3 which should be some low OHM value that varies from stator to stator so you will need a shop manual to know for sure. If the resistance is too high then your stator is fried and you will need another one.
    If the stator resistance is fine, then you check the AC voltage output of the stator with the bike running at about 4K RPM. Depending on your configuration (see shop manual) you will see anywhere from 40VAC to 60+VAC from each winding. If the output is fine then your problem likely lies in your regulator. If the output is low then the rotor has probably been partially demagnetized which means you will have to replace it.
    Friggin I-Tie electrical systems!
  1. solder connection keeps falling out
    By breakdirt916 in forum Bike Maintenance
    Last Post: 12-16-14, 07:03 PM
  2. Is this the Jig I need to make safety wiring easier?
    By Doc in forum Bike Maintenance
    Last Post: 02-09-07, 04:15 PM
  3. its so much easier if you don't crash :grin:
    By s a x m a n in forum Pit Area
    Last Post: 07-26-06, 08:20 AM
