Results 1 to 9 of 9
lowering idle to reduce heat
    If you're in a lot of stop and go traffic, does lowering the idle speed aid in keeping the engine temp down?
    My theory is a higher idle (~500rpm higher) spins the engine high enough that it'll generate a noticeable amount of heat raising that thermometer needle. So today I cranked the idle from 1,500 to 1,000 rpm to test it out.
    Dec 2003
    Ma
    no
    Work U HBerry's Avatar
    Nashua
    My bike can go up to around 219 degrees before the fan even turns on. If you are that worried about your bike overheating, install a fan switch so you can turn the fan on and off as you please, but how hot is this bike getting?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Waterbury, VT
    Lowering the idle might actually make the bike run hotter because of the decreased flow of coolant. You could try adding some water wetter or liquid ice to the coolant
    SSearchVT
    Jun 2005
    Originally posted by hessogood
    no
    YES
    Nashua
    Re: lowering idle to reduce heat
    I thought you sold your bike last summer?
    --HBerry
    LRRS# 285 - Retired
    04 ZX-6R
    88 EX500 - Broke
    Yeah, it doesn't look like it makes a difference.
    If anything, a slight rev of the bike dropped the thermometer needle a little bit because it circulates more coolant.
    And yeah, I did sell it.
    Oct 2001
    Bedford, MA
    IME richening the mixture can cool it off a bit though if you're careful.
    Especially if it's one of these newfangled bikes running at 16:1-20:1 during cruise & idle.
  1. NOVICE/AM RACERS - REDUCE YOUR TIRE BILLS!
    By Trackday Guru in forum For Sale
    Last Post: 06-05-13, 06:52 AM
  2. lowering a bike?
    By Adrenalinechic in forum General Bike Related
    Last Post: 09-23-08, 03:07 PM
  3. over-heat and 6k idle?
    By JunoAF in forum Bike Maintenance
    Last Post: 08-02-08, 10:46 AM
