Page 2 of 2 FirstFirst 12
Results 26 to 28 of 28
LT80 Quad, power to starter - fixed, spark - fixed, compression... ummm
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Re: LT80 Quad, no spark
    Quote Originally Posted by Cerberus View Post
    you say the head was loose the entire time?
    and it made poor compression?
    strange....
    haha, no - once i got spark I noticed the head was loose... and torqued it to spec. compression after that was 45psi.
    out of curiosity - what kind of difference would the oil trick gain? I'm gussing not over 100 still
    Dec 2005
    Near The Dragon
    here's the thing, if the head was loose and the engine ran that way for any amount of time, the head seal (gasket/head/cylinder deck surface) was almost certainly damaged by high temperature gas erosion, so just re torquing it won't fix it.
    i have seen the oil trick bump 20-30 psi compression pressures to 80 or 90 psi
    Get out while you can
    Find your own path
    Dec 2005
    Near The Dragon
    Re: LT80 Quad, power to starter - fixed, spark - fixed, compression... ummm
    update?
    Find your own path
  1. need to get this fixed!
    By Omahastylin16 in forum General Bike Related
    Last Post: 05-06-09, 10:49 PM
  2. mechanics pit quad - 2005 LT80 $450
    By Kitt in forum For Sale
    Last Post: 04-14-09, 01:55 PM
  3. Cylinder #1 broken spark plug fixed!
    By Ericthejet in forum Bike Maintenance
    Last Post: 03-16-09, 06:07 PM
