Results 1 to 18 of 18
Male/Female electrical connector
    Just Registered wookie's Avatar
    Sep 2006
    San Antonio, TX
    So I have been having electrical problems with the R6....it will suddenly cut off on me/then on/then off.....it is an intermittant problem. Usually happens when I'm out on the track (I cannot reproduce it in the garage).
    Well, after hours and hours of playing with the electrical system I found a connection that when I played with it the bike cut out. I unwrapped the electrical tape and found a male/female connector. I think the connection must loosen up/lose contact causing the bike to cut out.
    Summary:
    The wire are well connected to the connectors and I don't know if I have enough length left to replace the connectors. So, I want to make sure the connectors don't loosen up from one another in the future.
    Any suggestions? Maybe drop some solder in there? If I have to replace the connectors what type of connector should I use?
    2003 R6 - Track
    2000 SV650 - Street/Track
    Lifer burnham's Avatar
    Apr 2006
    massachusetts
    Re: Male/Female electrical connector
    What guage and how many wires in the connector? Hows Texas? Getting any?
    Sep 2006
    San Antonio, TX
    Looks like two 14 into one 14.
    I'm really concerned that if I cut away these connectors I might have a problem reaching or put tension on the connection.
    Here is a pic.
    2003 R6 - Track
    Apr 2006
    massachusetts
    Honda 3 wire 12 GA connector PN 31105-ML8-305. Has about a 6" lead coming off it and comes with solder and heat shrink.
    Sep 2006
    San Antonio, TX
    Texas is fan-fucking-tabulous. Cute friendly girls and a track day coming up tomorrow.
    BTW - the biggest difference? Since I moved here there have been several stories about someone shooting a burgler. In one case, a guy saw someone messing with his car in the parking lot outside his apartment...he just shot the dude...no problem/no charges against him. I swear everyone is packing down here.
    Nice, sounds like a plan. Thanks dude.
    2003 R6 - Track
    can't just goop it w/ dielectric grease & wrap it w/ electrical tape?
    Sep 2006
    San Antonio, TX
    I was thinking of that, but I don't have faith that the electrical tape will hold the connectors together.
    Loosing power on the track is just dangerous....it is like hitting the brakes unexpectedly. Then the bike goes on/off/on/off...like trying to ride a bucking bronco while holding a hand up...not cool.
    2003 R6 - Track
    Raymond NH
    Hold the male end with pliers and push an awl (pick) into the end of it a little to expand it. Test it and repeat until it fits snugly. It looks like it was made poorly.
    Sep 2006
    Around the corner
    Wook you move to Texas for what 6 weeks and your bike is
    Glad you are doing well Bud!
    you could use the di-electric and shrink wrap it with wire type wrap. if you start cutting in new pieces you are just creating another potential point of failure IMO right now the wires are just loose at the ONE point of connection tighten that and shrink wrap .... done
    The rule is:
    Dec 2005
    Near The Dragon
    i would hardwire & permanently join the wires.
    i used to always use these little beauties at the shop i used to work at.
    a piece of heavy gauge clear heat shrink tubing with a wad of low temp solder in the middle.
    looks like a clear crimp butt connector.
    Solders and seals the joint the joint air tight .
    works flawlessly.
    they cost between 25 and 75 cents per (expensive compared to other solutions) but they are so worth it
    Get out while you can
    Find your own path
    May 2007
    Southern NH
    Well I can see that the wires arent even connected....cheesh!
    Glad TXASS is working out for you...
    ...notice that you beat around the question of '...are you getting any'! Sure the girls are CUTE but....
    You are missed!
    Muhammad Ali.
    Durham
    or squeeze the female end with some pliers to shrink it. same effect. Female bullet connectors are usually made of sheet metal that is stamped and formed, over time repeated insertions and removals (yes i just said insert and remove) will cause the female side to expand slightly (shut up guys I know what you're thinking). Quick and easy fix. You can do this a couple times before the connector fails completely at which point get some new ones at radioshack and SOLDER NOT TWIST extra lengths of wire onto the old wires to extend them. Twisting new wires on is a guaranteed way to end up with an electrical failure down the road.
    Lifer ZX-12R's Avatar
    Candia, NH
    Quote Originally Posted by l3uddha View Post
    ...but if that's a pain in the ass twisting another piece on there will be fine. connect the new lengths to the new connector, then twist together with the wiring on the bike. heat shrink and tape it. badda bing badda boom.
    You are setting yourself up to be stranded on the side of the road somewhere. Twisting wires together is never more than a temporary fix to get you home where you can then fix it properly. Wires should be soldered and sleeved or have a contact properly crimped onto it.
    Sep 2006
    Around the corner
    l3 >>> blah blah blah = me >
    The rule is:
    Lifer Jayspeed's Avatar
    Medford, MA.
    Kev, maybe you can remove those connectors and replace them with brand new ones. Use the same style connector that way you won't have to worry about wire length. Those look like they just crimp on? If so, maybe you can squeeze the old crimp points to loosen and free up the wire instead of cutting and length off.
    Jay
    2013 gixxer 750
    2009 Ducati M1100s
    2017 KTM exc-f 350
    Sep 2006
    Around the corner
    NOPE
    Oh wait Damnitall forgot to ask .... Joel do you know anything about electronics or hardware?
    The rule is:
    Sep 2006
    Around the corner
    nope. nothing at all.
    Wellllll in THAT case :
    The rule is:
    Man. don't mundge the wiring on your bike. I've bought bikes before where the PO thought they were a rocket surgeon and rewired the bike. Using the same color wire. Speaker wire...
    Take a bit of sandpaper, clean up the contacts, reassemble with dielectric grease, and crimp it tighter with a pair of pliers. That's all you need to do.
  1. Replies: 1
    Last Post: 10-31-13, 06:07 PM
  2. Wanted: connector pin repair
    By sveesix in forum For Sale
    Last Post: 11-24-09, 11:26 PM
