Results 1 to 25 of 37
Multi meter
    Multi meter
    What do you guys use for a multi meter.. my old Sear unit is well old. Not sure it reading correctly and yes I replaced the battery... look at a modesty price unit..
    Lifer golden chicken's Avatar
    Attleboro, MA
    Re: Multi meter
    It kind of depends what kind of work you want to do.
    For automotive/motorcycle work I use meters by Electronic Specialities rather than Fluke, which is $$$$.
    Re: Multi meter
    Use is bikes mostly ,cars on occasion . Flukes are crazy money. Hopefully in the $60 range
    Re: Multi meter
    for some things, I prefer an analog meter, however most testing can be done with a digital meter, it's nice to have both
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Multi meter
    I've been using one similar to https://www.kleintools.com/catalog/m...o-ranging-600v for the past few years and it's been pretty solid.
    Re: Multi meter
    I bought a Craftsman multi meter many years ago for something like $30. Covers the basics, AC, DC, resistance, continuity, temp (in F and C)
    It's not the quickest to display measurements but it's definitely dead on as verified by calibration equipment.
    I also have a Fluke that I don't use nearly as often. It's faster than the Craftsman and has a backlight but offers no other advantages that I can see.
    I used a Klein meter a few times for work last winter and it seemed decent. Read back was reasonably quick, don't know what the owner paid for it but it did its thing just fine
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Multi meter
    I have had a fluke 83 for 20 years, probably have it the rest of my life.
    Lifer jimmycapp's Avatar
    Oct 2008
    NW CT
    Re: Multi meter
    Have a fluke that's at least 15 years old. Works great, but way overkill for basic MC stuff.
    South Coast MAsshole
    Re: Multi meter
    works when i need it but i don't use it a ton
    Etekcity Digital Multimeter, Voltage Tester Volt Ohm Amp Meter with Continuity, Diode and Resistance Test, Dual Fused for Anti-Burn, Red, MSR-R500
    https://www.amazon.com/dp/B01N9QW620...ing=UTF8&psc=1
    Point37s Garage Sale Thread
    Re: Multi meter
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 Picked this up after my similar styled Radio Shack unit let go at 35 years old. Compact, works well.
    Re: Multi meter
    I was wondering when someone was going to recommend a Harbor Freight grade, or at least HF Priced unit. Between my dad and I, we have probably 5 or 6 of those cheap HF multi meters. They do what we need for the most part but I may upgrade at some point.
    Re: Multi meter
    That Hioki is a proper Japanese meter, Dave at EEVlog reviewed it at https://www.youtube.com/watch?v=LCFEonQDkQU
    Re: Multi meter
    Sorry, was talkin bout the 12 dollar Etek. That's more in the HF price range
    Re: Multi meter
    yup it's cheap...picked it up in early 2018...have used it a few times...if it goes maybe i'll buy a HF one and give it a shot...i buy cheap for tools i only plan to use rarely...
    the HF version is half that price...can you say xmas presents?!...maybe i will pick up some flashlights too for stocking stuffers...
    https://www.harborfreight.com/7-func...ter-63759.html
    Haverhill, MA
    Re: Multi meter
    A lot of this depends on how accurate you need the meter to be.
    12VDC/24VDC stuff and just looking to see if there is power somewhere or not (quite a bit of motorcycle/car troubleshooting is this)
    or
    measuring high voltage AC sources and want to see the wave form
    or
    checking critical values in electrical circuits for troubleshooting
    or
    or
    or
    Sometimes the HF meter can be the right tool for the job, other times something like a Fluke is what is needed.
    Dec 2009
    Re: Multi meter
    Wish I had one of those Kline meters to hand out to people. Getting tired of getting my Fluke back only to discover someone gave it a stress test. I suspect the Kline unit would do nicely for what you intend to work on.
    Re: Multi meter
    Right now, I was trying to see if one of my coils for my project vintage bike is functioning correctly or not. My old Sears one is not working on any OHMs settings. I found that it's arching out on the frame the hard and shocking way. LOL Thanks for the suggestions...
    Re: Multi meter
    I am a Fluke guy, the 376 is my EDC, I also have an 87V, both more spendy than I think you’re looking for. My field techs all have 117’s which are pretty good for most tasks. I have not used the 114 but looks like the price may be right. I’m sure it’s fine, they make a great product.
    Re: Multi meter
    AstroAI Digital Multimeter TRMS 6000 Counts Volt Meter Ohmmeter Auto-Ranging Tester; Accurately Measures Voltage Current Resistance Diodes Continuity Duty-Cycle Capacitance Temperature for Automotive https://www.amazon.com/dp/B071JL6LLL...ing=UTF8&psc=1
    CCS/LRRS #83
    holland ma.
    Re: Multi meter
    UEI Phoenix as a primary, some random Fluke as a back up which i never use. Personally i find Flukes over rater and expensive but they are tough. I make money with my tools so i make sure to buy the best as i see it. UEI hands down.
    For random homeowner stuff Harbor Freight isnt a bad way to go for short money.
    Central Maine
    Re: Multi meter
    buy once cry once
    Re: Multi meter
    buy once cry once
    I prefer an analog over digital, there are things you can do with it, a digital can't do
    https://www.amazon.com/Simpson-260-8...9594589&sr=8-8
    Re: Multi meter
    I get that Fluke are expensive, I don't think overpriced is fair though. They make a solid product, have used their stuff for many years.
    I am also not surprised that Randy perfers analog. I'm not sure if we'll ever know his uses where it's "better."
    Re: Multi meter
    for testing a variable resistor / potentiometer, such as used for throttle position sensors
    a digital one will tell you if it is good full open or closed, it won't tell you if there are dead spots in between, with an analog, you can watch the needle sweep as you turn the throttle, if there are any hiccups on the way, the sensor is bad, if it's a smooth sweep, it's good. if the TPS in question is a simple arm sweeping a carbon ring type, the carbon ring (or whatever material it is) develops pits or scratches in the positions you most often keep yer throttle in, and you can ride a little faster, or a little slower smoothly, but right at the position you want to be at, the TPS is sending funky signals due to the wear pit, that can't be detected with a digital meter
    Re: Multi meter
    It absolutely can. Not with a shitty Home Depot DMM but a quality digital meter it’s not an issue.
  1. GTECH Performance Meter PRO
    By bump909 in forum For Sale
    Last Post: 11-02-09, 10:21 AM
  2. Just had a chat w/ a Meter Maid dude...
    Last Post: 08-29-08, 06:10 PM
  3. F*cking Meter Maids
    Last Post: 05-11-07, 11:19 PM
