hey everyone, Has anybody had any experience using this stuff for an exhaust leak where the aftermarket slip on pipe meets the tail end of the header?? I heard the stuff is good and will come off easily enough if you need to remove it. my aftermarket pipe is leaking from the clamp area directly under the center of the bike. its not bad enough to effect the power of my bike but its really pissing me off and its another area that water vapor can penetrate into.. since its at the bottom of the header I'm not to concerned about water finding its way into the motor ( if its possible ie the valves etc..) ANy thoughts, oppinions, experience with this????P.s. the after market pipe is to small in diameter to use a stock replacement gasket that would normally go in this area. 04F4i
Thanks
