Results 1 to 6 of 6
oil/gas in the airbox?
    Oct 2001
    Bedford, MA
    I just changed my air filter and there appeared to be a sheen of oil or perhaps gas that had gotten spit up through the rear velocity stacks... it had a reddish color so I am assuming it was gas.
    Problem? OK? The bike has always had stabilized fuel over the winter and probably never went more then 2 weeks without being started anyway.
    I cleaned it up and assume I should check it again in a few months and see if it came back?
    The bike is running fine but I am running a power commander, could this be from the bike running rich?
    Oct 2001
    Bedford, MA
    Never mind... crankcase ventilation feature to keep the old EPA happy.
    Jun 2005
    D'oh... beat me to it.
    I removed all that junk from the S-Hawk and replaced it with a proper baby seal killing greenhouse gas emitting gun-toting crank-case breather.
    Oct 2001
    Bedford, MA
    Ah.. I hadn't really traced the lines.. so there is probably a line from the crankcase to the airbox I could unplug?
    I don't think I care anyway as long as it doesn't hurt the motor.
    Jun 2005
    Should be... just make sure to affix an appropriate filter to keep the mung out of your crank case.
    I re-routed the breather and disabled the PAIR system. Doesn't hurt the motor, but it can't really help it either... AND since I hate baby seals so much and need every advantage I can get to beat Rossi, I absolutely had to do it.
    Oct 2005
    Kingston NH
    Just a quickie. I put a pcv valve on my gixxers' breather tube, mounted vertically. So she could breath out, but not back in. Just a thought.
  1. Bike dies when I put the airbox on
    By Garrett in forum Bike Maintenance
    Last Post: 06-02-14, 01:24 PM
  2. WTB: FZR400 airbox
    By hdscarbro in forum Wanted
    Last Post: 04-16-13, 07:18 AM
  3. 2000 Yamaha R6 with oil in airbox?
    By kumpy in forum Bike Maintenance
    Last Post: 09-11-12, 05:11 AM
  4. Oil in my airbox
    By Rusty the Scoob in forum Bike Maintenance
    Last Post: 08-02-11, 11:21 AM
  5. buy or borrow. 06/07 750 airbox.
    By Degsy in forum Wanted
    Last Post: 11-05-09, 11:30 AM
