Don't do the marble trick.
buy three of these OEM pink caps from the dealer. they're like $5/each
part # is 13859-41B10
it's the cap that's for the bottom of the air box, but they fit just fine for the PAIR mod.
install them on the bottom of the air box and top of the valve cover. some people safety wire the cap shut, but I used the PAIR hose clamps.
If you remove the PAIR system completely, you'll need to get a resistor 18-22 Ohm, 5-10wat to jump the plug from the wire harness.
If you dont, then you'll get an FI code which might be an issue if you ever get an FI issue and won't know.
I chose to remove the PAIR hoses and just connect the PAIR unit back to the wire harness, as I'm not a fan of jamming a resistor in the plug.
DONE
