Results 1 to 5 of 5
Plastic repair?
    Jon and Clara's Dad snaggle's Avatar
    Mar 2002
    Walpole,NH
    Plastic repair?
    So I have my fairing all glued back together. I guess my next step is to repair the rash and make the cracks disappear. My question is... Is there an additive to put into bondo to make it more flexible when hard so it won't crack up if it bends a ltiile? Or is there a totally different product I should be using? any help would be appreciated.
    '04 600RR
    Waterbury, VT
    Plastic repair?
    Go to a good autobody supply shop and buy a tube of the plastic bumper repair epoxy. You prep the surface by sanding with 40 grit paper (or just slide it down some pavement and pick out the gravel bits). When it hardens it is sandable, but still flexible. Hope this helps. Good Luck...
    SSearchVT
    Jun 2005
    uhhmmmi guess
    How much does it need to flex? you could use fiberglass/resin, layer it & sand it down.
    Mar 2002
    Walpole,NH
    Plastic repair?
    IT doesn't need to flex that much, just enough to install and remove it. I think I am going to put it all back together and run it for the rest of the summer, and see hoew the repairs hold up. If they are OK by the end of the season I will do the painting this winter
    '04 600RR
    KB KB's Avatar
    Manchester NH
    Plastic repair?
    BTW they do make an additive for paint to make it flexible. It's what they add to paint bumper covers and shizzzzz.
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Plastic Repair
    Last Post: 08-04-11, 10:05 PM
  2. ABS Plastic Repair?
    Last Post: 08-28-09, 03:03 PM
  3. How do you repair plastic? :(
    Last Post: 07-18-07, 04:35 PM
  4. Plastic repair question??
    By FireFly in forum Bike Maintenance
    Last Post: 09-13-05, 03:58 PM
  5. Can anyone help me with plastic repair?
    By hohum in forum General Bike Related
    Last Post: 06-26-03, 02:54 PM
