Results 1 to 25 of 29
Plastic Repairs
    Permanent N00b -Dutch-'s Avatar
    Feb 2014
    Pawtucket, RI
    Plastic Repairs
    Posting for a friend of mine in Braintree. He's got a cracked fairing and is wondering who he can take it to in the area for repairs.
    I know a few guys on here were talking about starting to do that sort of thing but I don't remember who/where they were.
    Re: Plastic Repairs
    I can give you some tips on how to repair yourself. Soldering iron, heat gun and then a crapload of filler.
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Re: Plastic Repairs
    Wire ties are workable filler.
    Also you can add strength by embedding metal across the damage. Staples (flattened), thin copper wire, nails etc. will all word for this.
    Mar 2004
    Lynn, MA
    Re: Plastic Repairs
    I've got to fix the Armorbodies I ruined last October.
    I'm thinking about fiberglassing the inside of the panel, body filler on the outside of panel, sand and rattlecan.....
    Am I gonna hurt myself?
    Re: Plastic Repairs
    Race plastics are totally different. $20 fiberglass kit from autozone. Goal should be for it to look okay from 100' or @ 100MPH. Unless you are me. Then the goal is just for it to stay together and pass tech.
    I spent a bit more time repairing the street plastics.
    Mar 2012
    Chichester, NH
    Re: Plastic Repairs
    Fiberglass on the outside, where previous fiberglass was "rubbed off" will add strength.
    Sanding fiberglass is harder than sanding body filler, but you are getting strength, not just looks.
    If you are very concerned about finish, then yes, final with body filler, but start with fiberglass.
    Race plastics aren't plastic (usually), but are fiberglass.
    Feb 2014
    Pawtucket, RI
    Re: Plastic Repairs
    It's a street bike so he wants it to look good when it's done. It'll need to be painted, too. 06' GSXR.
    I'm not interested in tackling it myself, I have enough to do to get my own bike up and running. Is this something any bike or body shops will do?
    Mar 2012
    Chichester, NH
    Re: Plastic Repairs
    If you need "finish quality" then you'll need to do 2 different things. First, structural repair, like described by 'bub's, then finish repair, which will probably be body filler to smooth everything out.
    Once you start talking body shop costs it may become more cost effective to just see if you can find a replacement plastic (flea bay, etc.).
    Re: Plastic Repairs
    If you want finish quality you need to get people like me to stop posting in this thread.
    I honestly didn't know anyone professionally repaired street plastics. I thought they were more economical to just replace.
    Feb 2014
    Pawtucket, RI
    Re: Plastic Repairs
    If it were my bike it would get the fiberglass treatment, I just don't want to do it on someone else's bike. It may be the case that no one repairs them professionally, I don't know.
    New Haven-ish, CT
    Re: Plastic Repairs
    To start, drill out the end of the crack with a 1/8" or smaller bit to keep it from getting worse.
    Super-Dooper User ɹǝʍoןandɹǝʍoן's Avatar
    Salem NH
    Re: Plastic Repairs
    I've successfully used in the past this stuff called problem plastic. It worked really good.
    Good luck.
    current: 06 zx6r, 03 450exc
    sold: 01 gsxr750, 01 RC51, 96 cr500, 98 superhawk, 00 sv650, 78 cb750, 98 dr350, 74 cb125
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Plastic Repairs
    I can't find Empire anymore that did sport bike plastic
    You probably can get all new plastic on
    DHGATE.com
    for less than 1 pc from a dealer etc
    The calculus of hate
    Re: Plastic Repairs
    So, no? Nobody knows of anyone that does this professionally?
    Mar 2012
    Chichester, NH
    Re: Plastic Repairs
    Professionally, no. I've only seen this as a DIY trick. Mostly for those of us who are too cheap to buy a new body panel. This is the type of fix that takes some time to do, so when time is money, plastic repair is more expensive than replacement.
    May 2010
    Somersworth, NH
    Re: Plastic Repairs
    Thats the best way to do it Johnny... we can get it done in a weekend day if you wanna bring em up to my place we can hammer em out and primer them in my 'paint booth'
    Mar 2004
    Lynn, MA
    Re: Plastic Repairs
    Fuck yeah Brian....call ya later!
    Re: Plastic Repairs
    Looking for recommendations on where to get my HyperMotard's fairing repaired. My guess is that it's ABS plastic:
    Plastic Repairs-img_8296-jpgPlastic Repairs-img_8297-jpg
    Any suggestions?
    Re: Plastic Repairs
    Re: Plastic Repairs
    I'll check it out, but I was hoping to pay someone to fix this for me...
    TWINS! xrocket21's Avatar
    Central Maine
    Re: Plastic Repairs
    I know youre asking for a professional, but I inherited a harbor freight style plastic welding kit and I have got pretty good with it. As long as you have the right plastic, you just heat it to soften it, smear/stitch it toegther so the plastic mixes, let it cool, and sand. Even came with stainless steel mesh you can embed and it really strengthens it.
    Lifer golden chicken's Avatar
    Attleboro, MA
    Re: Plastic Repairs
    I had ok luck with two-part epoxy repairing cracked plastic engine covers on Mercedes. I'm pretty sure they're made of ABS as well, since regular superglues didn't seem to work at all.
    Central Maine
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    Re: Plastic Repairs
    Any suggestions?
    Depending on how anal you are, acetone, a small paint brush and literally 2 minutes of your time.
    Brush some acetone on the mating surfaces, put the pieces together, hold for 30 seconds. Acetone melts ABS and then once it's evaporated, the ABS rehardens and bonds.
    LRRS 878 Clapped out Gixxah
    Re: Plastic Repairs
    Don’t post pictures of the broken fairing: that would make it too easy.....
    Quote Originally Posted by wiggeywackyo View Post
    You can also buy products designed for above, which is known as “Solvent Bonding.” Medium viscosity product is a lot easier to use with thicker parts. Acetone will turn ABS to goo if you aren’t judicious.
    That said, remounting a broken tab can be a challenge because it’s carrying the load.
  1. Trailer Talk - Repairs and Mods
    By Kurlon in forum Pit Area
    Last Post: 04-22-14, 06:16 AM
  2. Last Minute Repairs...
    By Damjr in forum General Bike Related
    Last Post: 05-23-11, 08:30 PM
  3. Fiberglass and tank repairs
    By The Snowman in forum Bike Maintenance
    Last Post: 02-22-09, 02:18 PM
