Results 1 to 19 of 19
SV650 Castle Nut Tool
    Permanent N00b -Dutch-'s Avatar
    Feb 2014
    Pawtucket, RI
    Anyone in the South Shore / Metro West area have one they'd be willing to loan out? I'm looking to swap out my front end this weekend.
    High maintenance priss
    Central MA
    Re: SV650 Castle Nut Tool
    If the SV nut is the same size nut that was on the TL1000R, I have it in Upton MA.
    [Edit] - According to this product, it looks like they should be the same as long as you're talking about a 2nd gen SV650 http://komotodraggin.com/steering.html. I'll measure it up when home tonight if it helps.
    Feb 2014
    Pawtucket, RI
    My hero. Yes, it's a 2nd gen. If I can't get my hands on one a bit more local to Brockton I'll be in touch.
    Central MA
    Sounds good.
    The tool I have has 6 teeth with an ID inside the teeth of a hair over 38mm.
    SV650 Castle Nut Tool-img_20140904_225802_637-jpg
    Lifer Ductard's Avatar
    Sep 2013
    South Boston, VA (not a typo)
    Don't suppose that's the same tool you'd use to remove the swingarm from an '04 GSXR-600?
    It's got a castle nut on it, but I'm not sure what size and I need to change swingarms...
    LRRS 919
    May 2013
    Epsom, NH
    The swingarm and steering castle nut are different but the one in the picture looks like the one for engine mount?
    I ordered their "set" http://komotodraggin.com/toolset.html
    Sep 2013
    You don't happen to be headed to NYST this weekend, hmmm?
    LRRS 919
    May 2013
    Epsom, NH
    i totally would if I was home but unfortunately I won't be back for another month
    Lancaster, CA
    Screwdriver and hammer
    Feb 2014
    Pawtucket, RI
    Oy.
    Feb 2014
    Pawtucket, RI
    A pair of channel locks with padded jaws worked a treat.
    i was gonna say a drift and a hammer will work
    i have one & i'm in quincy...but it's for the GSXR. will it work?
    Feb 2014
    Pawtucket, RI
    I don't know, already done though.
    i have all the specialty sockets for the GSXR if someone needs to use one.
    What other speciality tools are handy for the SV?
    Feb 2014
    Pawtucket, RI
    JIS screwdrivers/bits if you go digging around under the tank. Other than the really big sockets I haven't run across anything that wasn't doable with what came in a $100 assorted tool set from Northern Tool I picked up a while back.
    Rocky Hill, CT
    ^ This
    JIS drivers and bits are a must if working on ANY japanese motorcycle. Means you can actually reuse the carb screws they form out of butter.
  1. Replies: 1
    Last Post: 09-05-14, 05:54 AM
  2. Castle Socket for CBR1000 swingarm?
    By Mondo in forum Bike Maintenance
    Last Post: 10-16-09, 03:43 PM
  3. castle island 4/25
    By Omahastylin16 in forum Rides & Events
    Last Post: 04-24-09, 10:44 PM
