Trying to order a rebuild kit but I'm not sure which bike a Nissin 11/16 radial master cylinder comes from.
Help please and thank you.
Okay, what I'm asking is, if your bike has an OEM Nissin radial master cylinder please check it and post up the year, make and model.
Nissin on OEM 07 gsxr 600
not sure if its 11/16
Well Keith, 11/16 is kinda the important part.
Is it free?
Okay then, is it as much as or cheaper than a master cylinder rebuild kit for a Nissin 11/16?
Wirelessly posted (BB 8310: BlackBerry8310/4.5.0.161 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
Does it say 11/16 on the part? I can check my 06 750 when I get home.
I just looked at mine and it is a Nissin but I can't find any other markings on it.
Lemme see about getting a pic posted. I believe the numbers are underneath close to the bars.
I just looked again and mine says 3/4.
Dammit and thank you for checking.
I assume the '06-07 600 is the same as what I have.
11/16 Nissin anyone?
Does this help, Paul?
http://www.peterverdonedesigns.com/1000RRmaster.htm
www.justfuckinggoogleit.com
http://www.denniskirk.com/jsp/produc...ductId=pH57653
Woops! Missed the Nissin part...
GL1000
Thanks Chuck!
I still think that watch would look dazzling on you.
Nah, I need the numbers, or at least the ticks. Movado only has the jewel at the 12 o'clock spot.
Otherwise, I'd be saying something like "it's something o'clock".
BTW, 06-07 is the same. Not sure about 04-05.
Edit: Just checked the 04 and 05 fiche. The M/C sub assembly is the same for 04-05 as 06-07. However, 06-07 had 2 different types of sub assemblies. 04-05 only one. Not sure if this means that 06-07 has 2 brands of M/C (Nissin and other).
