Long story short I botched the timing on painting and clear coating a recent project. Just put down my firs coat of clear, on one portion everything was perfect on the other portion I fucked up the timing between coats so the clear is giving me the wrinkly/cracked look.
Question: Am I okay just to wet sand down the portion I screwed up and then go back to clear coat or should I wet sand, then apply another layer of base coat then clear again?
The base coat is just a dark machine grey, not metallic or anything special.
