Page 1 of 4 1234 LastLast
Results 1 to 25 of 85
RC51 No Start/ No Spark
    TWINS! xrocket21's Avatar
    Central Maine
    Last summer, about 2 weeks before my shoulder surgery, the RC died on me. I rode it 100+ miles that day, and cruising along on flat ground going 40 in 4th, it simply shut off without a hiccup, backfire, light, flicker, anything.
    -When you turn the key, the fuel pump cycles
    -it has fuel
    -no FI light
    -battery is good
    -fuel commander lights up and seems to be okay
    -all fuses are good
    -quick check of wires shows nothing chaffed
    -pulled the plugs and layed them on the frame and see no spark
    I have the manual, and Ill keep at it, but wanted to check if there is something obvious I might be missing?
    Re: RC51 No Start/ No Spark
    power commander is suspect...
    Central Maine
    It came installed when I bought the bike a decade ago, so Im not familiar with how it is installed. I think I can just take it out of series and jump around it? it is obviously the old non usb one.
    You have exceeded my knowledge in this area. I've never put one on a bike, for this reason. I assume you just unplug and run tha stock map.
    Central Maine
    then what makes you suspect the fuel commander?
    It lights up normally when I power on :o
    They are notorious for dropping fuel maps and generally being annoying. Though some people swear they are the bees knees.
    Central Maine
    its been solid for me since 06!!!
    Ill look into it though
    Central Maine
    after not touching it for 8 months, I had some delusion of getting it running last night and riding it to work today
    Lifer SwiftTone's Avatar
    Norwood, MA
    I would just take the Power commander off to see. It's easy as it just involves unplugging 2 plugs from the harness and plugging the stock harness back together.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Ashford, CT
    My dad had one go bad in a Harley, it did just what you described. He unplugged it and the bike fired up on the stock map.
    Jeff
    Central Maine
    Will try tonight!
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    If you don't have spark then the power commander(which only controls fuel) isn't the problem, kick stand switch or kill switch would be a good place to start.
    Feb 2008
    Rhody
    Quote Originally Posted by myzx6 View Post
    +1
    A bad CDI could also be the culprit, maybe a bad tipover sensor too.
    Hyper
    bad crank position sensor ?
    Member Fitron's Avatar
    Mar 2016
    Winchendon, MA
    Could be several things. Have you had a look over at Honda RC51 Forum : RC51 Motorcycle Forums ?
    You probably pissed it off by lugging it at 40 in 4th gear!
    Freak Posting snowborder's Avatar
    Mt. Wannahuckaloogi
    Have you checked the tip over sensor located in near the rear fender?
    2001 RC51!!!
    2007 Husky SMR 510 - no longer... blown tranny
    Central Maine
    fuel pump wont cycle with a bad tip over sensor or kick stand switch, so both of those I believe to be fine.
    There is the main plug for the fuel commander, and then theres a second smaller one I cant get to. Broke a bolt taking a radiator off and threw in the towel there.
    Lifer union's Avatar
    Blackstone, MA
    I'll come take it
    Its probably the PC. It should just unplug. The PC IIIrs have been known to get a bit flaky.
    James
    Central Maine
    I'll come take it
    I unpligged the main harness, but theres a smaller plug WAY DOWN INSIDE and I cant get to it.its like behind the coolant overflow tank.
    I have a new t-stat so Ill just start ripping coolant shit out anyway.
    Then I can fix the broken bolt too
    Norwood, MA
    My plugs were easily accessible.
    Central Maine
    well, I have the fairings off, the tank up, and the airbox removed and still cant get to it
    Central Maine
    ooo, promising news, it looks like the wire I am having trouble accessing is the "ignition wires for the pc3" shown in figure D here:
    http://www.powercommander.com/downlo...eng114-311.pdf
    ignition wires and Im having park problems.....
    You're welcome in advance. lol
    Central Maine
    Got the PC tottaly unhooked.... still no spark
    changed the t-stat while I was in there so I at least got SOMETHING done. On to the next thing I guess.
    At least it is only gonna be 70 tomorrow.
    Hahaa! I cursed myself! Sorry to hear. That sucks. Next up. Coils, cam position sensor, crank position sensor.
  1. RC51 won't start
    Last Post: 04-25-13, 12:22 AM
  2. No spark help
    By shortbus in forum Bike Maintenance
    Last Post: 10-08-12, 12:06 PM
  3. Spark Plugs 06 R6
    By BrianC in forum Bike Maintenance
    Last Post: 07-19-11, 07:32 PM
  4. No spark?
    Last Post: 07-29-07, 01:28 PM
  5. RC51 - Tough to Start
    By CBRent in forum Bike Maintenance
    Last Post: 07-22-07, 05:41 PM
