Results 1 to 20 of 20
How to replace steering head bearings
    Senior Member kumpy's Avatar
    May 2012
    Norton MA
    I'm looking for a mechanic to help change upper & lower steering head bearing in my 2000 R6. I'm on a pretty tight budget cause I just bought a house and was initially thinking of attempting it myself but from what I hear, I'm going to need press to install and remove the bearings which I definitely do not have. Does anyone know if I can do the job with basic home hand tools? Anyone know if its a easy job for someone with limited skill and tools? Anyone know anyone who could help me with the replacing the bearings and not charge $300+? I live in Norton MA so any recommendations would have to be within reasonable distance.
    Senior Member SVenpointsixtwo's Avatar
    Jeffersonville, VT
    Re: How to replace steering head bearings
    It's easy to do without a press, all you need are some brass drifts and some sort of deadblow hammer. You can punch/cut out the old races very easily, although you may need a torch to get the lower race off the steering stem/lower triple. new ones will go in easily with drifts, and a length of appropriate-diameter copper tube is helpful to get the new lower race back onto the steering stem.
    SVenpointsixtwo
    2015 KTM 350 XCF-W
    Wirelessly posted (iPhone 4s)
    Pm Peter Kates and see what he'll quote ya. His name on here is GMDBoston.
    May 2012
    Norton MA
    Hey Oreo, Pete was the one who gave me the quote, I'm trying to save on some dough while educating myself on how to work on my bike!
    Gahtcha. I was gonna say, that sounded about right.
    Feb 2007
    I always do it with just a regular hammer, a long screwdriver and millions of tiny taps. A huge padlock is a great way to drive it back in flat (you tap on the lock to flattet the blow. This tool will make short work on the bottom frame ones http://www.bikebandit.com/park-tool-...FYFo4AodYQH1Gg. But you can drive out the bottom with long screwdriver and many taps.
    Derry NH
    When I did mine, I made one of those tools with a scrap piece of conduit. Just cross cut it twice about halfway down and bend out the tabs slightly. Easy peasy. As for the lower stem bearing, it's not that tight and can be easily done without a press. I used a chisel to start it moving, then a brass punch once I could get behind it, and just small taps on alternating sides. To put the new one back on, I thing I just found a tube of appropriate diameter and length, and tapped it back on, even PVC will get the job done. To make it even easier, put the new steering head races and the stem in the freezer(after removing the lower race) and it will shrink them, making things easier to reassemble. To make it even easier, heat the new lower race with a hair drier, and put it on the very cold stem, may not even need to tap it at all.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Harbor freight sells bearing drivers/puller sets as well, if your not a home made tool kinda guy. The most important part of installing the new bearings is just to make sure you only press them on by the race that is being held against the material, ie pressing bearings on a shaft press by the inner race, into a bore use the outer race. Failure to do so will result in damage to your fresh new bearings, and will not be covered by any expressed or implied warranties mentioned or alluded to in any and al terms of use and /or written or verbal service terms... ever. .
    Other than that I have nothing to add.
    Edit. Derr taper bearings never mind. Still a good rule to follow for any futer bearing jobs though. Good luck.
    I wrote up a thread on doing this.
    I believe jt's called "the (not so) great GSX-R rebuild."
    May 2010
    Somersworth, NH
    Is this good for wheel bearings also??
    Quote Originally Posted by RIZXVIR View Post
    10 Piece Bearing Race and Seal Driver Set
    I just replaced both upper/lower steering head bearings and front wheels bearings on the "new" front wheel I acquired.
    Pretty easy to do. I ended up bringing the lower race and lower triple to GMD to have PK press the race onto the triple. Took all of 5 minutes. The rest I did myself and it took maybe 30 minutes.
    Jut make sure you have a way to keep the front of the bike off the ground. I used jack stands on top of milk crates. I placed them under my frame sliders.
    I'm thinking of a car jack, a piece of pvc pipe and trying to lift the house.
    I am betting it is a win win. The house wins and the bearing gets seated.
    I think this is the thread, for those that are lazy like me...
    http://www.nestreetriders.com/forum/...Gixxer-Rebuild
    "Gixxer", not "GSX-R", it seems...
    Bearing racer? How many times did Jim say racer in that thread?
    This thread motivated me to go downstairs and knock the bearings out of the CB400 frame. Going to spring for a decent tapered set. She's earned it.
    Member martia's Avatar
    Grafton, MA
    I had a local machine shop press on the inner bottom race... The outer race on top and bottom tap them out with a screw driver. Then i tap the race back with a ruber hammer..
    Most motorcycle problems are caused by the nut that connects the handlebars to the saddle
    I cut the inner race off my lower triple with a dremel cutting wheel and a blunt chisel, being careful not to hit too hard with the mallot.
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    I just bought the HF set for 25.99 with a coupon. Prior to that I used sockets in the jumbo sizes to drive in both races and bearings. Just flip them over so the end that you put the wratchet in is facing up and once you have the right size its easy to do both.
  1. How to replace front wheel bearings???
    By G21forme in forum Bike Maintenance
    Last Post: 07-01-11, 01:00 PM
  2. Steering Head Bearing
    By Devil1 in forum Bike Maintenance
    Last Post: 05-12-08, 05:18 PM
  3. Brakes/head bearings
    Last Post: 06-01-06, 11:14 AM
  4. Steering head bearings are too easy...
    Last Post: 07-14-03, 09:39 AM
  5. Steering Head Bearings - 96 EX500
    By VinceF2 in forum Bike Maintenance
    Last Post: 07-15-02, 08:50 AM
