Hey, everyone. I had such success here the last time I posted a question about removing a stubborn bolt, so here goes Round 2:
One of the bolts that holds the brake pads into the caliper (in the attached photo, the bolt that is directly across from the 'o' in 'Tokico') has become rounded-off. A hex/allen key simply spins inside the head of the bolt. As you can see, the bolt lies flush with the caliper surface. How do you remove such a bolt? A friend has suggested driving an appropriately sized Torx bit (or similar) into the head of the bolt and seeing if I could get the bit to impress into the sides and grip.
Thanks for your suggestions.
