Results 1 to 25 of 33
RPM's Drop with Throttle
    Westfield MA
    Hey all, been working on my bike the last two days trying to get it back on the road. But, a new problem has come up. Whenever i open up the throttle the RPMs drop almost to stall unless i back off. All ive done to the bike since i pulled it out of the garage was clean the Carbs out. Any ideas? thanks!
    Nate
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Re: RPM's Drop with Throttle
    check the air filter. Clean as needed.
    Dec 2005
    Near The Dragon
    sounds like dirty jets or bad fuel or improper adjustment
    if you have a tps, sometimes a bad or disconnected tps can cause that kind of problem too
    Get out while you can
    Find your own path
    Westfield MA
    whats a tps again?
    Could be clogged/ blocked pilots and/ or mains in the carb bank
    spark plugs could be just about fouled
    bad fuel
    mice in the airbox
    kinked fuel line
    There's more...
    1988 Ninja 600R?
    No tps. (throttle position sensor)
    If it ran fine last fall but not anymore, check the basics which Bergs listed.
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    your throttle is upside down, flip it over so rpms go up instead
    Westfield MA
    okyes, theres no TPS lol
    as for the spark plugs: Would i have problems getting the bike started if they were fouled too?
    what else should i look for? just let me have them Bergs. Its nice out so i dont mind looking lol.
    Checked the Fuel Line and it looks good
    KB KB's Avatar
    Manchester NH
    If it ran before you cleaned the carbs then I would say you might have eff'd something up when you cleaned the carbs.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Westfield MA
    but i didnt do anything different than i usually do when i clean carbs. I checked and replaced all the components (that I could get to as Kawasaki has sealed some parts of the carb off from the public) back to the way they were. I double and triple checked my work
    Quote Originally Posted by JunoAF View Post
    Plugs can be the root cause of many running and/ or starting issues.....carbs too (obviously).
    Go over the simple things first. Like others have stated, if it ran when you stored it and it doesn't run correctly now, best to check the easy stuff.
    Once all that checks out fine you move to the electrical (however I'm of the opinion that would be jumping the gun so I'd hold off until you have the fueling squared away).
    Since you were in the carbs already you very well may have installed something backwards, upside down, inverted, bent, broken, etc.
    I'm saying plugs and/or carbs on this one.
    The symptom is exactly what plugged pilot jets do. They need to be reamed out with pressurized air...
    Westfield MA
    ok cool, thanks guys. I'll go down and pull the carbs again and re-clean just to make sure. I guess there is a very good possibility that I installed something backwards or missed something. I'll post up tomorrow if i find anything
    Gabba Gabba Hey Stiggy's Avatar
    Jan 2009
    Wirelessly posted (Mozilla/4.0 (compatible; MSIE 6.0; Windows CE; IEMobile 6.12) 320x320; VZW; UTStar-XV6800; Window Mobile 6.0 Professional
    TPS is trottle position sensor. doubt you have one on a carbed bike. sounds like you might have an intake leaks. check the carbs for proper seating.
    06 RC46
    Quote Originally Posted by Stiggy View Post
    I have one on my carbed bike...
    Nov 2004
    Boston, MA
    yes, but you are BERGS....rules do not apply
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    Finally! Someone who gets it!
    Dec 2005
    Near The Dragon
    there were a few carbed bikes that came down the assembly line with a tps. presumably for spark control.
    for instance...
    Find your own path
    Lifer DuncanMoto's Avatar
    Clogged jets are my vote.
    If it runs just run gas with Sea Foam through it for 10 minutes. Let it sit for 2 days, then it will run fine. ;-)
    If not then it was something else, but you only spent 10 work minutes figuring it out.
    KB KB's Avatar
    Manchester NH
    Is this Sea Foam stuff for real or is it one of these internet myths?
    Anyone ever uses and had great results? I've been curious about this Sea Foam stuff.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    It has many applications though it's not the first thing I reach for in my tool kit.
    I'm about to use it to de-carbon the top end in my truck.....add it directly into the brake booster line, run, change oil, done.
    It has cleared up some issues with bikes I've worked on but I'm in the camp of going in and physically cleaning carbs.
    Dec 2005
    Near The Dragon
    i heard nothign but good about it, but never used it myself that i remember
    Find your own path
    Well here's what it did for me. Bergs picked up my wife's newish 2009 KLX250 a couple of weeks ago and brought it to me. It had 270 miles on it. The kid I got it off of let it sit since August with gas in it. Bergs can attest that it would only idle and not run. I mean you twist the throttle and it would die. We let it warm up for 10 minutes on choke and still it would not run. So I was thinking "DAMN I have to take apart the carb on a new bike cause the guy didn't know any better to use stabil." Anyway Bergs said "hey why don't you try seafoam?" and said "what the f%$! is seafoam?"
    So I did my research and ended up calling the company. Per their instructions, I mixed a gallon of gas with ___ Ounces of Seafoam got the bike to idle for about 10 minutes so the new fuel mix would be in the carbs. Tried to open throttle and then killed the engine by opening throttle. I them proceeded to pump the throttle and flood the carb. I let it sit for 2 days. I pumped the throttle the second day to try to get more gas flooding into the carb. after the second day I tried to start it. It took a little to get it warmed up and after about 10 minutes the thing really came to life. Ran a little rough with the mix, so I drained it and put in fresh gas. Runs great now. I put the rest of the mixed gas in my ford explorer figuring it won't hurt it. 30 miles later my check engine light has gone off after it's been on for over 6 months
    In other words not a myth. And yes I will become a dealer for their products shortly.
    Westfield MA
    hey all, sorry it took me longer than expected...im lazy and its been cold. Anyway, since it was so nice of a day i pulled my carbs again to clean them out. Checked my airbox and what do you know...a fur and skeleton bundle was hangin out in the corner. I dont think this had that much to do with my problem because the carcass was all i found and it looks like hes been dead a long time. Anyway, i did look at my jets again and this time i found they were partially covered in this bluish/green film. some still slimy and some dried on. What is this crap? Bad gas? is it the fuel stabilizer? im thinking that might of been my problem like you guys said. what do you think?
    Dec 2005
    Near The Dragon
    don't honestly know this for sure, but i always tend to think blue/green deposits are from 2-stroke fuel being put in..
    but yeah, clean up all traces of that garbage and you should be fine
    Find your own path
  1. How to drop your bike
    By gymkhanaJOSH in forum General Bike Related
    Last Post: 08-20-12, 05:33 PM
  2. Replies: 59
    Last Post: 12-24-11, 12:12 PM
