Pulling the tank will give you all the access you need and the carbs will have enough fuel within to idle for quite a long time.Quote:
Originally posted by mikeb
will just pulling off theside fairings give me enough access to the carbs to do that? i have to pull the tank to check the air cleaner so i can't run it while doing that. i could rig something up i guess.
I like the vacuum leak concept. There are some bolts just under each carb that are used for synchronizing the carbs. Maybe one fell out.
