Page 2 of 2 FirstFirst 12
Results 26 to 39 of 39
End of season oil change?
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    What I do....
    Before storage I put in new cheap dyno oil and a new filter
    I also give it a healthy shot of Fogging oil
    Spring take I good ride then drain it and put in
    MObil 1 4xt motorcycle oil stays till next fall.
    I can only parrot that supposedly old oil has acidic combustion by-products that can corrode internal surfaces. Especially in storage where moisture accumulation will remain until motor is hot again.
    Glen Beck is John the Baptist
    Raymond NH
    It's true, oil builds up acid from the by-products of combustion, but it also contains buffers that neutralize it. Old oil will not hurt your engine by corroding it. I can show you parts that sat in 5000 mile, used oil for a few years with no corrosion.
    Aug 2004
    Baltic,CT
    04ZRX Gerbing Jacket or jacket liner
    mmm, mmm ,mm toasty
    .... naked-daytrader's Avatar
    May 2007
    You're all a bunch of anal-retentive pussies.............I've been riding for 17 years and I haven't winterized one of my bikes!
    Just get a new bike every spring.........
    I Dance With Will
    Oct 2002
    unknown
    Quote Originally Posted by richw View Post
    What I do....
    and i also use same oil.
    just changed oil today. popped in the cheap FRAM car filter. fits nicely. FRAM does not list bike filter for ZX10. i found a cross ref.# awhile ago.
    don't worry, i have OEM filter when spring comes.
    "fuckit!"
    KB KB's Avatar
    Manchester NH
    I just leave the oil in them that's been in there for about 40k or so. Then plug in the heated gear a few times during the wintah and go for a rip and that's it. I love a nice cold tire 200 foot power burnout on a cold tire. I lube the chain before the park in the shed.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    I always ride a bit in the winter, I use cheap oil & change alot.
    www.bostonmoto.com
    Forum Rules
    Senior Member nerijusj's Avatar
    Somerville, MA
    I also use Mobil 1 4T oil. Last winter I changed it thinking, I won't be riding anymore, but nice weather just kept holding up on weekends. So I was riding up until christmas. Now my oil change costs about $45- oil & filter. When the spring came, I rode for a while then changed the oil again. This year, I'm thinking about changing the oil right before I put the bike for storage, and keep riding with the same oil in spring. Too expensive to throw away a fresh oil ( changing it again in spring ).
    Other than that I just put some Stabil in gas. That's all I do for winterizing the bike.
    ZX10R
    Ned
    Somerville, MA
    Kurt, holy sh@t! You RIDE that ZRX! That's a bit more than 15 k miles a year ! I average about 9k miles a year, and I thought that was a lot, hah. Well, I don't ride in winter though
    ZX10R
    Ned
    Somerville, MA
    Yeah Kurt, see ya next season! Although I'm not putting my bike away just yet. Still hoping to see temps in upper 40s-50s this year so I can go for a spin now and then. The bike will go to "hibernation" when salt hits the roads. Don't wanna be riding on that sh@t.
    ZX10R
    Ned
    Aug 2004
    Baltic,CT
    MIne are heading to the basement today
    Junior Member akira's Avatar
    Boston, MA
    Re: End of season oil change?
    would it be ok to just start it up once a week and let the alternator do its work for a bit? sorry, i'm definitely not mechanically inclined...
    Quote Originally Posted by 04ZRX View Post
    Lead acid batteries will discharge between 2-5 % per day (depending on ambient temparature) just sitting there. If they get depleted below 10.6 volts on a (12 volt battery) they will no longer hold a complete 100% charge.
    It is advisable to charge them at least once a month to prevent that problem.
    If you do deplete them below that 10.6 level, they will only hold 80% of a total charge. Next time you do it, it gets worse.
    Yes you have been lucky.....
    Senior Member ahtune69's Avatar
    Jun 2005
    Needham
    kira#2 your better off buying a batery tender and let it charge during the winter.
    Mike
    05 636
    Green Machine
    07 Husky sm510
    Quote Originally Posted by ahtune69 View Post
    yes, AND a bottle of Sta-Bil
  1. Oil Change
    By KillahTillah in forum Bike Maintenance
    Last Post: 04-11-14, 06:40 PM
  2. WAP change
    By jcbell1007 in forum Site Info & Suggestions
    Last Post: 06-25-09, 10:47 AM
  3. Oil change
    By amajew in forum Bike Maintenance
    Last Post: 08-21-07, 05:13 PM
  4. First Oil Change
    By HBerry in forum Bike Maintenance
    Last Post: 09-09-04, 11:48 AM
