Results 1 to 9 of 9
Seat pad glue removal
    Hey all, I have to remove my foam seat pad to repaint my tail. How would I go about removing the adhesive from the pad to prep it for going back on the bike? What type of glue do people use? Thanks.
    Re: Seat pad glue removal
    Goo Gone is a popular adhesive remover. WD-40 also can be used. You'd apply it and let it soak into the glue for a few hours, then scrape off.
    I would imagine any heat stable flexible glue would work to apply the foam. Shoe Goo would be my first thought.
    2016 BMW S1000XR
    Concord NH
    There are plenty of different adhesive removers out there, so you could probably find a bunch of options.
    Turtle wax makes a label and sticker remover in a spray can. I bought some a couple years ago because the side panels (stick on) were peeling off my Silverado. I grabbed it since it was a good size can, and it worked really well. It smells citric based (like many of the removers), and works best when you spray it on and let it soak in for a little bit.
    Still have a tiny bit left in that can, and I use it whenever I need to remove jday/HS stickers, especially when they've been baked on real good.
    Lifer golden chicken's Avatar
    Attleboro, MA
    I'm lazy so I'd probably just slather rubber cement on top of the existing glue and slap the seat pad back on.
    I'd be a little cautious of anything that dissolves glue might dissolve the foam too.
    Haverhill, MA
    Quote Originally Posted by bobcat1059 View Post
    I'm guessing that bobcat1059 is referring to a race bodywork tail that only has a thin layer of adhesive backed foam attached to it and is trying to get the adhesive/residual foam off of the fiberglass for painting.
    Attleboro, MA
    Ah. In that case, mineral spirits.
    New Haven-ish, CT
    Heat gun on low to soften the adhesive and WD-40 or mineral spirts to clean it off
    Jun 2005
    I'm partial to SEM Solve for sticker funk, but above recommendations work.
    https://www.semproducts.com/product/sem-solve/solve
    For a race tail repaint, I would just tape the edges of the foam and paint.
  1. Replies: 0
    Last Post: 08-03-13, 12:10 PM
  2. re-glue Stomp grips
    By Marc R in forum Bike Maintenance
    Last Post: 05-28-13, 08:44 AM
  3. Rear seat removal??
    By wfd38383 in forum General Bike Related
    Last Post: 07-12-07, 09:44 PM
