Results 1 to 21 of 21
Snap ring tool / help replacing shift lever (Cambridge)
    Member ae's Avatar
    May 2011
    Anyone around this=cambridge, MA area with a snap-ring tool that can help me replace my shift lever?
    Thanks.
    Last edited by ae; 06-20-12 at 01:35 PM. Reason: "This" was supposed to mean Cambridge from the title.
    Jan 2009
    Waltham
    Wirelessly posted (Tilt)
    I have one in waltham that you can use. I only have one of the bits it came with but worse comes to worse they are like 6 bucks at autozone.
    Re: Snap ring tool / help replacing shift lever (Cambridge)
    I have one in THIS area...
    Member ae's Avatar
    May 2011
    Cambridge?
    Posting Freak FAST GSXR750's Avatar
    Granby Ct.
    I have one also. But don't know what area you speak of.
    GSXR750 GS650 Street Tracker
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    Go to Sears or any hardware/automotive store. Snap ring pliers are cheap money and essential if you need a pair as you can see.
    Granby Ct.
    Like $5.00 at Harbor Freight. Lowes and HD have em also.
    It'll cost more in gas to have someone meet up with the pliers, than to just pick up a set at a store.
    FYI, he's referring to Cambridge, MA. Not Cambridge, NH.
    EX 105 : CCS Atlantic, Mid Atlantic, South East, Florida, and WERA
    Sponsors: Motul, Michelin/STS, K&N, Woodcraft
    Member ae's Avatar
    May 2011
    Thanks guys. Wasn't much about the tool. I needed help with the process. Wordtooyomomma was going to help me but I got caught up with something else
    Look on youtube, I bet someone has already made a video how-to.
    Newton's Third Law of Stupid. For each fact there exists an equal and opposite alternative fact.
    Oct 2007
    Peabody Ma
    If you can get to Peabody with your bike I will replace it for you.
    Quote Originally Posted by ae View Post
    Cambridge?
    Woops! No, I didn't see the Cambridge part...
    Member ae's Avatar
    May 2011
    Thanks everyone. Was doing this to recover from a Lowside. But it looks like there is more damage such as bent handlebars / forks.
    stop crashing
    Member ae's Avatar
    May 2011
    stop crashing
    Trying
    So, I might have to wait for a while to get my bike fixed. In the meantime, I did some research and found out that if the front forks are tweaked and not bent, loosening the front fork upper clamp bolts might fix it.
    Is it worth trying this with my complete novice non-existent skills + without a front stand so I can have a bike to commute to work on until I can get it fixed?
    Nov 2007
    You can't effectively race a bike with tweaked front end but as long as it's not too severe there's no reason you can't ride it.
    Usually the triples twist, not the forks themselves. They are softer than the forks by design.
    If it's semi-bad they can usually be bent back, GMD can do it for you.
    Zip-Tie Alley Racing
    LRRS/CCS #103
    Member ae's Avatar
    May 2011
    Not racing yet. I have yet to start doing trackdays. PMed GMD to ask for a quote.
    I am Dead now
    Oct 2009
    The tax State of the Nation
    Is it a inner or outer snap ring? It makes a difference on the snap ring pliers you buy. No, not like a left-handed monkey wrench either. I have both types over here in "THIS" area with at least four different tip sizes too.
    Member ae's Avatar
    May 2011
    Quote Originally Posted by ptk-napalm View Post
    Thanks. Unfortunately that is no longer the (only) problem. I might have bent forks/handlebars that need to be fixed. I did replace the lever but the tool I bought from Autozone sucked. And the clip seems a little flimsy. So there is a general bad feeling surrounding the current state of my bike.
    Nov 2007
    like i said you can commute on a lightly twisted front end or twisted handlebar... you're not racing it.
    LRRS/CCS #103
    I am Dead now
    Oct 2009
    As long as the ring is in there snug & not wobbling in the grove it should be fine. Have Peter Kates at GMD check out you forks/handlebars better being safe than sorry.
  1. For Sale - Parts & Tools | Snap-on solus pro scan tool $350/trades??
    By myzx6 in forum For Sale
    Last Post: 11-19-17, 12:46 PM
  2. For Sale - Other | snap-on tool box $300
    By caloots in forum For Sale
    Last Post: 12-10-16, 02:30 PM
  3. No clutch lever? No shift lever? No footpeg? No problem.
    Last Post: 08-29-11, 01:25 PM
  4. Circlip/snap-ring removal: flathead or special tool?
    By dhawks in forum Bike Maintenance
    Last Post: 09-02-10, 02:36 PM
