Results 1 to 17 of 17
socket question
    Lifer greenmonster's Avatar
    Aug 2003
    socket question
    My bike calls for a 16mm spark plug socket. So, off I go to Advanced Auto and then to Auto Zone, both here in Waltham. Both had standard type plug sockets, but no metric. What they did have were 16mm deep sockets. Would these also double as spark plug sockets, or do I need a spark plug-specific 16mm?
    Lifer eboos's Avatar
    socket question
    The spark plug specific sockets are pretty much only needed if you need the socket to hold onto the spark plug if you don't have much access for your fingers. If you do have good finger access, start your threading with your fingers to avoid cross threading.
    Aug 2003
    socket question
    Quote Originally Posted by eboos View Post
    Come to think of it, my plugs are DEEP down there! I'd definitely need the rubber collar insert to lift em out and put em in. Oh, well...I'll have to keep on searching. Online this time....see if bikebandit has them.
    Just Registered Wishbone's Avatar
    Jul 2006
    socket question
    I had the same problem with trying to hold my plugs with a normal plug socket. The normal plug socket was to big to grip the small tip of the bike plug. So I took a bottle cap, cut it down then stuffed it into the socket and threw the rubber in after it to hold it in place.
    So be creative
    socket question
    Go to sears, get a craftsman 16mm deep socket, loosen the plug, use a rubber hose to grab the old plug, use rubber hose again to start threading the new plug (so you don't cross thread) then tighten with socket. Works every time.
    Mike 37
    Aug 2003
    socket question
    Great idea, Mike! Definitely gonna try it. (Just watch...as soon as I leave the Sears store, boxes of 16mm spark plug sockets will be getting delivered to their shipping dock. LOL)
    Sep 2007
    Hinsdale, nh
    socket question
    you could also loosen the plug up with the 16mm socket and use a pc. of rubber hose to grip the plug ,just push it down over but cut it long enough so it reaches withplug and you have enough to grab
    Jun 2005
    socket question
    Quote Originally Posted by mmracer37 View Post
    that's a damn fine idear.
    Waterbury, VT
    socket question
    16 mm basically crosses over to 5/8. Take a plug into the store with you and see if a 5/8 plug socket fits. I don't like to use regular sockets for plugs because of the potential of breaking the porcelin.
    SSearchVT
    Jul 2006
    socket question
    Quote Originally Posted by vintage ex race View Post
    Or you could take a piece of rubber hose and use it to hold the plugs
    Aug 2003
    socket question
    Quote Originally Posted by fasterthanu View Post
    HAHAHA!! I saw that! Its deja vu all over again!
    Aug 2003
    socket question
    I have a 5/8"....but its a c.h. too wide in its outer circumference to fit down the hole to access the plug. And I dont have any old ones sitting around to test the fit. Tossed 'em with the last change out. Doh! This is one case where being nice 'n tight is NOT a good thing!
    socket question
    couldnt you just use a 12" extension with the deep socket?
    EX 105 : AMA, ASRA, CCS South East, and WERA
    2014 ASRA SuperStock National Champion - Amateur Division
    Thanks to my sponsors: Motul, Michelin/STS, K&N, Woodcraft, Yoshimura R&D All Balls Racing, Galfer, Sidi Boots, Vortex
    Aug 2003
    socket question
    Yep...I have the extension. Ill try whats been suggested here. Deep socket with the rubber hose. DAMN!! Now thats the fourth time thats been mentioned. lol I think this thread has run its course. Great ideas to boot. As long as I dont crack the ceramic......
    Lifer joeswamp's Avatar
    Sep 2006
    Swampscott, MA
    socket question
    Just noticed this thread, gotta say the "rubber hose on the spark plug" idea is one of the best in the history of motorcycle repair.
    I first learned of this technique about ten years ago when I cross threaded a spark plug hole by putting a deep socket on it and turning just the socket with my fingers (no ratchet). Those aluminum threads are ridiculously soft and it can be tricky to judge what the correct angle of the plug should be.
    When I took the head to the bike shop to get helicoiled, the mechanic pointed out the hose trick as the best way of limiting torque on the spark plug, been doing it this way ever since...
    Joe
    04 Thruxton (Street)
    01 SV650 (Track)
    Apr 2006
    Beverly, MA
    socket question
    Wow, I'm going to use that hose trick for all spark-plug related jobs. I cross threaded one of the plugs on my gf's Civic once, man that sucked.
    Thanks for the tip!
    KB KB's Avatar
    Manchester NH
    socket question
    You got a purdy hose!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. need to borrow head socket
    Last Post: 07-03-07, 01:09 PM
  2. Pre-reg question.
    By 13 in forum Pit Area
    Last Post: 08-24-06, 02:22 PM
  3. Question...
    By MissTwisties in forum Controversial Topics
    Last Post: 09-15-05, 09:21 PM
  4. question
    Last Post: 10-07-03, 11:23 PM
