Results 1 to 14 of 14
How do these spark plugs look?
    Lifer Punjistick's Avatar
    Norwell, MA
    I can obviously tell the difference between erroding, oil fouled, and melting but I can never tell the difference between black, tan, light grey for how a normal plug should look. I think spark plugs can be any of those colors depending where you look. These are probably fine, they only have about 15k miles on the original plugs, but thought I would get some second opinions before I put them back in.
    Wirelessly posted (BlackBerry8530/5.0.0.508 Profile/MIDP-2.1 Configuration/CLDC-1.1 VendorID/105)
    Pic? Don't see anything but I'm on wap so that might be it. Btw when can I get your airbox to you Alex?
    Lifer JohnnyV's Avatar
    Westborough, MA
    Re: How do these spark plugs look?
    I'm no expert on plugs and can generally tell the general condition as well, however with the past few bikes I've owned and the amount of shit it takes just to get to the spark plugs, at 15k if I'm questioning whether or not to replace them I would just do it. Might as well spend the $20 now while everything is apart.
    Norwell, MA
    Derek, I posted 4 pics but maybe you can't see them on WAP.
    Doing a quick search online people are saying that they can go 25k+ miles (one guy says he got 40k) on iridium plugs. I might just pick up some and forget looking at them for a while unless the bike is running poorly. I find it interesting how the suzuki manual says to replace every 7k and inspect every 4k. Do they really think the engine is going to eat plugs every 7k miles? Seems overkill. Unless it's another lawyer cover their ass thing.
    Lifer R1's Avatar
    Somewhere you dont know...
    Degs, you should be able to see them on WAP now.... they have to be embedded to view in WAP
    They all look pretty good, IMO.
    Not tan (which suggests a lean condition or excessive heat) and not black (which suggests a rich condition or burning oil)
    Norwell, MA
    Cool. Thanks bergs.
    Dec 2005
    Near The Dragon
    pretty much perfect condition.
    assuming the gap is right, reinstall to proper torque and run 'em
    Get out while you can
    Find your own path
    Thanks keith. They look great to me Alex
    I'm going to be the wierdo, if you're running pump gas, I'm going to say they look a touch rich. Between the ethanol and other agents in the gas, they should be lighter on the insulators. 'course these weren't pulled in the heat of the moment in a plug chop so...
    Color transition on the electrode is consistent across all 4, insulator (what I can see) looks consistent, run it?
    Oh Josh...
    Plugs don't get any better than that my friend.
    Norwell, MA
    Thanks for the replies guys. I just checked the gap and tossed them back in.
    They weren't pulled while holding the clutch and cutting the ignition and also I ran some stabil through the engine before I stored it for the winter so I'm sure that can't help the color.
    Lifer Stromper's Avatar
    Eastern Ct
    Some bad gas deposits but heat range and carburetion seems good
    Lifer DuncanMoto's Avatar
    Wirelessly posted (BlackBerry9000/4.6.0.297 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    Looks like you use Hess gas to me...
    Am I right?
    Plugs look fine.
  1. Spark Plugs 06 R6
    By BrianC in forum Bike Maintenance
    Last Post: 07-19-11, 07:32 PM
  2. Spark Plugs
    By akira700 in forum Bike Maintenance
    Last Post: 10-10-08, 08:18 AM
  3. Cleaning Spark Plugs
    Last Post: 02-14-08, 06:40 PM
  4. spark plugs
    By oreo_n2 in forum General Bike Related
    Last Post: 04-14-03, 07:32 PM
