Results 1 to 8 of 8
speedo cable...
    Southwick, Matachusetts :)
    speedo cable...
    Last season on one of my last rides, my speedo cable fell off and was dragging on the asphalt, lucky for me a friend of mine was following me on his bike and noticed sparks under my bike...now I am paranoid that it may fell again and maybe when I'll be riding alone and won't notice it. Seems that maybe the vibration makes it to unscrew and fell off?
    www.elementsofbalancemt.com
    www.facebook.com/misstwisties
    Everybody to the limit!
    Winchester, MA
    speedo cable...
    It's a well-known problem with the EX250/EX500 bikes. Happened to my EX500 and pretty much everyone with an EX that I know at one point or another.
    I put some threadlocker (Go to a hardware store and ask for some, they'll know what you're talking about and it's cheap) on mine and tightened it down as hard as I could, and it's never fallen off since then.
    speedo cable...
    And I suppose if need to, you can unscrew it after with a tool? Thanks for the info!
    Winchester, MA
    speedo cable...
    If you're concerned with being able to unscrew it later, you should ask for "nonpermanent" threadlocker. It doesn't hold as well as the permanent kind, but it can be removed with tools if needed.
    Mar 2004
    Manchester, NH
    speedo cable...
    You could try safety wire as well
    LRRS/CCS #669
    speedo cable...
    ...and what is that? (sorry, I'm a little ignorant about these things...)
    NOT laughing with you {~; bemused's Avatar
    Deer Island, OR
    speedo cable...
    aka "lock wire". find / drill a hole in the head of the bolt that's unscrewing itself, pass some thin-but-strong wire thru it, then attach it to some non-moving part... keeps the bolt from being able to move.
    easier to show than to explain... any of the racers here (or someone w/ experience fixing aircraft ) could show you how.
    jeff f
    '97 RF900R
    Northshore/Beverly, MA
    speedo cable...
    Just ask for "Loctite Blue" Small bottle...
    Clean up both sets of threads...alcohol works good, a couple drops to one set of threads screw it back on, and Forgetaboutit.
  1. Resetting speedo
    By JPK in forum Bike Maintenance
    Last Post: 11-19-12, 08:12 PM
  2. Speedo cable?
    By j4eric in forum General Bike Related
    Last Post: 11-18-11, 11:04 AM
  3. Buell speedo/odo way off
    By Kitt in forum Bike Maintenance
    Last Post: 08-05-11, 01:34 PM
  4. Speedo App for Smartphones
    By peterz85 in forum General Bike Related
    Last Post: 05-31-11, 08:49 AM
  5. Speedo cable for an EX500?
    By MissTwisties in forum General Bike Related
    Last Post: 07-22-08, 10:42 PM
