Results 51 to 75 of 90
where to start?
  1. #51
    Yowza LaRNZ's Avatar
    Oct 2004
    Tewksbury , MA
    Re: 88 EX500 Track bike Build
    Quote Originally Posted by catch2otwo View Post
    ok so i picked up mike's 88 ex500 this weekend. its been sitting for two years. i haven't pulled it out of the truck yet but i figured id garner some opinions today. this is the description in the ad
    some of the other things i noticed was the front brake rotor needs to be replaced and the caliper needs to be rebuilt. not sure if the rear brake works.
    here was my to-do list.
    1. pull off carbs - clean
    2. drain fuel
    3. remove key cylinder
    any ideas on the key cylinder? i figure i can just rig up a switch for on/off and just have a push button start? just going to be a track bike so no worries about needing a key.
    send me the ignition, i can fit keys to it, jus gotta pay the shipping
    .:|LaRNZ|:.
  2. #52
    san fran
    Quote Originally Posted by LaRNZ View Post
    i already broke it into little pieces
    Tuono
  3. #53
    Lifer McBiggity's Avatar
    May 2003
    Charlton, MA
    Re: where to start?
    Best pic i could find, but my first ex had a basic automotive tach. Also had a toggle switch and push button start, no key.
  4. #54
    san fran
    Re: where to start?
    Quote Originally Posted by McBiggity View Post
    k cool, so an auto tach will work.
    ok found another wiring diagram in the book just on the ignition circuit. looks like if i connect the white wire (regulator) to the yellow wire (goes into 4 pin connector on the kill switch) it should complete the circuit and leave the kill switch as the on/off switch.
    Tuono
  5. #55
    san fran
    Re: where to start?
    k a little more progress
    got the carbs off, cleaned the chain, and finished wiring. dont know if it works yet, battery is dead.
    overall, everything looks pretty clean. carbs still had fuel in them so hopefully theres nothing clogging anything up.
    Tuono
  6. #56
    May 2003
    Charlton, MA
    Re: where to start?
    take the carbs completely apart. Clean the pilot jet very good. The pilot jet clogging is a known issue w/ Ex's
    san fran
    Re: where to start?
    will do. thanks for the tip
    also, what size and brand is that tach?
    Tuono
  8. #58
    Nov 2007
    Re: where to start?
    That left handgrip is not in the right place, especially for a track like Loudon!!
    I saw you mention that you cleaned the chain... but you should replace that chain and sprockets. By the looks of it they are wayyy past gone.
    Looks like a fun little project. You'll get it running, just time and patience and a few bucks should be all it takes
    Zip-Tie Alley Racing
    LRRS/CCS #103
  9. #59
    san fran
    Re: where to start?
    Quote Originally Posted by ceo012384 View Post
    ya, i was going to move the left hand grip out, im not used to having my hands that close in.
    on the chain and sprockets. they just seem gummy. just looks like a little surface rust. doesnt seem like the links are loose or anything. still feels pretty stiff. but then again, i dont know how long its been run before it was put away. think i still need to replace them?
    Tuono
  10. #60
    Lifer Punjistick's Avatar
    Norwell, MA
    Re: where to start?
    It's an EX. As long as the chain is not binding and it's safe, who cares.
    May 2003
    Charlton, MA
    Re: where to start?
    I don't remember any details on the tach. I got rid of that bike 3 years ago.
    I would say it was about 4" diameter.
    The Fastest Indian! kamikaze's Avatar
    Jul 2008
    Delhi, Indiaaahh!
    Re: where to start?
    The front rotor looks more rusted than george bush's brain. I think you would need to replace the entie bake caliper assembly.
    I was talking to a few folk and most of them suggested replacing the spockets along with the chain
    Sold: 1999 Kawasaki ZX-7R
    2005 Pulsar 180 DTSi
    Owning: Pulsar 220 DTSi
    http://www.dhairyagupta.com
    http://bostonbiker.blogspot.com
  13. #63
    Norwell, MA
    Re: where to start?
    Since it's going to be track only, you're gonna want the EBC rotor anyways. Also you can just buy a caliper off ebay from a newer EX instead of spending the time on rebuilding the caliper you have. It's probably about the same price as an o-ring kit.
    Re: where to start?
    Good god, that brings back memories of my first race bike. 88EX It was HIDEOUS, but I had fun with it. I gotta try to find some pics...
    holland ma.
    Re: where to start?
    might want to check the valves real quick while you got it that far apart. its only a few extra minutes for a lot of piece of mind. get a cheap lawnmower fuel filter for that thing too.
    Norwell, MA
    Re: where to start?
    +1 I've got an '01 and the paint is flaking all around the gas cap opening. Lot of little bits that want to clog things.
    san fran
    Re: where to start?
    hope everyone had a nice thanksgiving. now, got the carbs apart and cleaned everything. here are a few pics
    now question time. the two slides. i cant figure out what makes them move. the only carb ive ever had apart is from my dirtbike. now when you twist the throttle on that, the cable pulls the slide up. on these carbs, twisting the throttle opens up the butterflys. i dont see any linkage or anything to move the slides.
    question two. in the pics below, what is the thing im sliding over? in the second picture you can see the gold rod.
    question three. one of the gas inlets is plugged off by the big black cap. why is that? the other side has a gas line running into it, but the other carb is capped. i dont see any way gas can make it to the other side.
    note: the safety wire in the pics is attached to the things im asking about in question 2. but when i got it, its not saftey wired to anything, just kinda there.
    overall, the jets were all cleaned and all the passage ways blasted. lots of crud came out of the gas inlet when i sprayed carb cleaner into it. both needle jets were nice and sharp, nothing was nicked or damaged.
    Tuono
  18. #68
    Norwell, MA
    Re: where to start?
    The safety wire is attached to the choke. Not sure about the other stuff.
    san fran
    Re: where to start?
    ooo ok thanks
    Tuono
  20. #70
    Senior Member FTMS's Avatar
    Warren, NH
    Re: where to start?
    Air veloctiy is was moves the slides. On the air box side of the carb there is a large opening that goes into the diaphram chamber. Be carfule with the diaphram on the slides, they don't like chemical cleaners. When you put the carbs back together, take compressed air and shoot it into the the opening to the diaphram chamber to see if the slides are working.
    2004 Honda VTR
    1998 Honda VTR (Track Bike )
    1990 Honda CB-1
    1973 Yamaha RD350
    http://www.ftmsnh.com
  21. #71
    san fran
    Re: where to start?
    Quote Originally Posted by FTMS View Post
    cool. i was real careful with the diaphrams, they looked real sensitive. anyone have any idea why one fuel intake was capped off?
    Tuono
  22. #72
    May 2003
    Charlton, MA
    Re: where to start?
    Not sure, but both my ex's were like that. Had no issues.
    I don't think that side is a fuel inlet. I'd check the manual to be certain.
    san fran
    Re: where to start?
    ok i just found it strange. the manual is at my gf's house thats why i asked before checking it. ill look it up when i get over there. just seems strange to me that fuel isnt going to both from the same spot. maybe putting fuel to both will give it 100 hp?
    Tuono
  24. #74
    holland ma.
    Re: where to start?
    fuel is feed threw that big line. those are the vacuum lines. one is capped the other goes to the petcock assuming you still have one. no fuel will flow from the tank without a vacuum source. that center black tube is the fuel overflow. most just leave it off.
    looks like youve got a bit of varnish in those carbs. just let it soak in something for a while.
    san fran
    Re: where to start?
    thanks, so all the lines look fine?
    Tuono
  1. 636 won't start
    By apollomx681 in forum Bike Maintenance
    Last Post: 08-18-08, 09:39 PM
  2. Wed, 7/9, start in RI
    By jeantarrou in forum Rides & Events
    Last Post: 07-08-08, 07:49 AM
  3. start um up let um run
    By beet in forum Bike Maintenance
    Last Post: 12-17-03, 07:47 AM
