Results 1 to 9 of 9
Steering head bearings are too easy...
    Raymond NH
    Need to replace the lower bearing in the Bandita. I had heard removing the old races was an awful job and was prepared to suffer. I must say that it went quite easily thanks to some tips I'd read prior to doing the work. One tip is to cut deeply into the lower inner race on the steering shaft and crack the race with a cold chisel instead of trying to pull the race off. This worked like a charm and took all of five minutes with my little pneumatic cut off tool. The other tip was to heat, bend and grind a drift at an angle that allowed it to get a good purchase on the outer race. Two hits with a hammer and it fell out. Off to the bearing store in Chelmsford during my lunch break... Should have it all back together tonight. Lemme know if anyone wants to borrow the "custom" drift. It'll prolly work well on wheel bearings too.
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    I never had too much trouble getting the bearings out (the chisel/hammer method has always worked great except in cases where the bearings are REALLY old, like 20 years old frozen solid). I have only had trouble getting the new bearings back in (since I didn't really wanna pound em in with a hammer)... Now I have a nice hydraulic press from harbor freight ($130) that has served me well for many a bearing.
    Cheers,
    Chris
    Raymond NH
    I have an old arbor press that was found in the Malden Mills fire debris pile and it works great for stuff like bearings. My plan was to put the triple tree in the freezer and the new bearing in the oven prior to putting it all together.
    Jul 2002
    Everett, MA
    Yup, that'll work too Thats what I usually do for wheel bearings. Just make sure the oven is hot enough (400) and everything is fully degreased before putting it in the oven... I had a bad little experience with putting wheel bearings in that way, when my wheel was not totally degreased... Can you say oven fire
    Cheers,
    Chris
    Raymond NH
    Damn. Eastern Bearings cannot get the right bearing with the proper seal so I had to go to the dealer. Gonna be a week or so before my wife can ride. At least the weather is terrible...
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    what about "all Balls" bearings.
    they even had bearings.... tapered ones to replace the BB's and races, on the fiddy?!!!! And that thing is from '72
    http://allballsracing.sureshopping.com/default.asp
    Raymond NH
    Too late, but thanks for the link.
    I use All Ballz in the race bike.
    Put the new racing in the freezer for a while before you install it. It will go in easier (right Gary?)
    degs
    Raymond NH
    Got the job done on Friday night. No problems at all except for the long wait to get the part from the dealer. Install was a snap. Bike feels right again.
    Wife picked up a Joe Rocket Phoenix jacket on Saturday for herself. Loves it.
  1. How to replace steering head bearings
    By kumpy in forum Bike Maintenance
    Last Post: 01-13-13, 08:57 AM
  2. steering head bearing replacement...
    By dwaltz61 in forum General Bike Related
    Last Post: 08-21-08, 07:28 PM
  3. Steering Head Bearing
    By Devil1 in forum Bike Maintenance
    Last Post: 05-12-08, 05:18 PM
  4. Brakes/head bearings
    Last Post: 06-01-06, 11:14 AM
  5. Steering Head Bearings - 96 EX500
    By VinceF2 in forum Bike Maintenance
    Last Post: 07-15-02, 08:50 AM
