Results 1 to 23 of 23
Stock 1974 Yamaha RD 350
    Member clutch's Avatar
    Oct 2008
    I am having some lack of power issues with this stock 1974 Yamaha RD 350.
    Does anyone here know how to fine tune one of these bikes, or a mechanic/shop that does.
    Thanks for any help.
    Current whiplist:
    MST/Pikes Pike---------Transformer/Sky Hooked
    1098s-------------Interstater/Time machine( Just sold)
    DRZ 400 Tarded---Urban assault vehicle
    Road King---------Date bike/ Hangover bike
    XT 225-----------Grocery getter/Packie bike(For Sale)
    RD 350---------Giant Killer
    Past whiplist, I drink to them all.....
    Raymond NH
    Re: Stock 1974 Yamaha RD 350
    Assuming the carbs are clean and not messed with, the fuel and oil supplies are clean and fresh, and the spark plugs are new, the first thing I'd check is crank seals. They tend to dry out and fail with age and non-use and then the bike runs really lean and makes less power than it is supposed to.
    Message TLRMan. Something tells me he could rebuild that entire thing in a medically induced coma.
    If he pays you a visit, don't stand in front of him when he sees the bike. You might get wet.
    Lifer Expat's Avatar
    Mar 2007
    Lack of power could be a lot of things, rings could be worn = low compresson. Carbs out of balance or dirty, crankcase oil seals as already mentioned, maybe even a slightly slipping clutch?? Without more of a description, it is hard to say.
    I am just outside Worcester and could probably diagnose for you but I travel a lot for work so getting together could be tough!!
    Feb 2010
    Southbridge
    LAndrics BOMO can take care of her. i personally have a specialty in vintage bikes.. and i just so happen to have a specialist on 2 strokes in my pocket... not literally but, you know what i mean.. seriously, i can get her runnin' right for you again.. pm me or call 774-200-6395
    Degsy: "i never had red hair"
    Member VTRumble's Avatar
    Kingston, MA
    WWW.usa2strokers.com
    WWW.2strokeworld.com
    If you haven't been to either of these, the forums are good.
    Central MA
    Somewhat related...check out this RD:
    http://www.bikeexif.com/yamaha-rd400-custom
    Lifer Stromper's Avatar
    Eastern Ct
    Terrible ignitions
    There is a place that has soild state upgrades... look at walnecks for add
    My race tuned rd had to be warmed up then cold plugs put in
    Kingston, MA
    You can pick up a Dyna ignition from Vintage Smoke off one of the above forums. I bought one for my r5, nice to get rid of the points.
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Hmmmm....If after all the regular stuff has been checked like fuel, filter, sparkplugs clean have you done a crankcase leakdown test? A leakdown test consists of plugging the exhaust and using a adapter and fitting in the intake then pressurizing the engine.
    May wish to inspect the reed valves. All very easy stuff to do BTW. Just the first time is a little confusing.
    . dipthat's Avatar
    Boston, MA
    2 strokes is the shit, I used to own a yamaha RX-Z, and the big brother is of course RD. Add some castrol something to the 2t (if they have it here, which I doubt it), that thing will smell GOOD
    2004 Yahama RX-Z
    2004 Yamaha 125-Z
    2008 Honda CBR 600RR, bitch is SOLD
    Castrol R30
    Eastern Ct
    caster bean oil ... castrol
    metal for the masses jpallein223's Avatar
    May 2010
    Lebanon CT
    while the bike is at idle spray carb clean on the boots of the carbs, and where the boots connect to the reed cage(s). if you hear a spike in rpms (where it revs up after you spray) you have a leak somewhere in the boots and or reed cage gasket. On all the old bikes they seem to get cracks boots and or gaskets tend to go. i would start there if all regular checks have been done
    Old and Slow Sheppo's Avatar
    Westford, Ma
    lots of good ideas I would check the points first and then upgrade the ignition to points less
    Posted by Jane in BoxChat
    Oct 2008
    Here is what I have done so far:
    Added in-line filters
    Pulled carbs and cleaned them
    Visual on the points, they look fine
    Sync the carbs
    Replaced the following:
    Spark plugs
    Petcock
    Fuel lines
    Air filter
    Replaced oils
    I think Rambunctous may be on too something?
    As for jpallein223 suggestion, that tip seems easy enough to perform, thanks I’ll give it a shoot.
    VTRumble, I have posted on 2SW, and will check what kind of feed back I get from there. As for USA2S, I’ll take a look at that one, Thanks.
    Landricscustoms, I may just take you up on your offer to consider working on this RD. You being in Framingham is an easy target for me to get it to you, thanks.
    I can do the spray test, but the pressurization, I got stuff, but not that kind of stuff.
    The bike is close, real close. Its just one of those tuff itches that I can’t seem to scratch.
    Thanks for all the feed back guys. I hope to have this bullet smoking the way it should be soon.
    Current whiplist:
    May 2010
    Lebanon CT
    if it dose rev up then you have a crack somewhere or a leaky gasket which should eb replaced. Get that thing going we need more 2 strokes out there!!!!!
    Mar 2007
    Did the 74 have reeds??
    Oct 2008
    Hello landricscustoms
    Back on 11/1/2011 I posted for some advise on one of my bikes, a 1974 Yamaha RD 350. I received some responses by others that were helpful. But I took from your reply that you would be interested in taking on the challenge to get this bike dialed in and running, as it should.
    Quote: LAndrics BOMO can take care of her. I personally have a specialty in vintage bikes.. And I just so happen to have a specialist on 2 strokes in my pocket... not literally but, you know what I mean.. Seriously, I can get her runnin' right for you again.. pm me or call 774-200-6395
    If you are still wiling to help me with this bike. That would be great!
    So if you are interested, please let me know how and when it would be best to connect with you.
    Thanks, Clutch
    Current whiplist:
    Feb 2010
    Southbridge
    yup! we're interested!! give me a call 774-200-6395 or 508-241-2666 (bomo)
    Eastern Ct
    Stay with him but for both of you I have had good sucess bringing old rubber parts back to use by filling the cracks with black silicone.... and it makes them shiny too.
    Also points may be fine but old condensor can't be viewed and ignition sucked brand new
    KB KB's Avatar
    Manchester NH
    I would go with crank seals!
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. For Sale - Parts & Tools | WTS: 2012 Yamaha R1 stock clear wind screen, stock mufflers
    By Synyster in forum For Sale
    Last Post: 03-23-14, 09:13 PM
  2. 99-02 Yamaha R6 stock exhaust & wheel set
    By kumpy in forum For Sale
    Last Post: 05-01-13, 03:47 PM
  3. 1974 Yamaha RD 350 B
    By clutch in forum General Bike Related
    Last Post: 12-21-12, 10:50 AM
  4. Replies: 0
    Last Post: 11-04-09, 08:04 PM
  5. WTB 04 Yamaha R6 stock front blinkers
    By Mystic in forum For Sale
    Last Post: 04-09-09, 09:21 PM
