Results 1 to 5 of 5
Suspension question: lowering front forks
    Senior Member kumpy's Avatar
    May 2012
    Norton MA
    Got a 2000 R6 and I keep hearing how twitchy the bike is, but when I ride my it's definitely a more stable ride and I feel like I'm wrestling with the bike to lean over especially in quick left and right flicking turns. I feel like its stable but really sluggish low and high speed turns. I remember talking to the original owner and he was saying purposefully setup the bike to sit tall so it's about 2 inches taller ride height. He didn't tell me why he set it up taller than normal, think it was for ground clearance? So what I did today was lower the front 3/10th of an inch. Took it for a ride around the neighborhood and seems way more manuverable at low speeds. I'm running a reworked front fork from Traxxion Dynamics and Penske Triple in the rear. Bike setup for 185lb rider but I'm only 150lbs. My question is, is lowering the front forks a common adjustment to setup the bike? Would it be considered the first step? Would tire choice be considered the 1st step? Should I have raised the rear tire?
    #331 CBR929RE's Avatar
    Bridgewater, MA
    Re: Suspension question: lowering front forks
    you didn't lower the forks. you lowered the front of the bike (pulling the tubes up through the triples). I seriously doubt he raised the bike 2 inches as I doubt there's that much adjustment even available. raising the rear is typically a better option than lowering the front because you don't loose any ground clearance going that way, you actually gain some. ride it and find out if you like it.
    May 2012
    Norton MA
    Sorry for the confusion. I RAISED my front forks, meaning my front tire went up and the triple tree went down. I went to a steeper rake and less trail. I feel like the seat height is about 2 inches taller.
    Get Weird! maxim_X's Avatar
    Fairhaven, Ma
    Yes that's a very common trick to make steering quicker. If you go too far though the bike will become unstable.
    LRRS EX 151 AMSOIL
    JCBernier -- You-tube
    May 2010
    Captial Region, NY
    Raising the forks is a common way to "destabalize" the front end, however as in everything in life (or any kind of tuning), you simply don't get something out of nothing. It is always a compromise.
    The general rule is as you raise the forks, you lose swingarm angles; and if you have conventional forks, you will also lose forks travel as you raise them. If you have a Penske, you can always raise the shock height (within adjustable limits) to recoup some of the swingarm angles back due to raising the forks.
  1. For Sale - Parts & Tools | Gen2 sv front end with intimdators. Also stock forks and front wheel
    By Mgiossi in forum For Sale
    Last Post: 11-18-18, 10:14 AM
  2. Front Only Suspension
    By ScottyJ in forum General Track Day Talk
    Last Post: 04-02-16, 07:56 PM
  3. 06-07 R6 front end/forks
    By lrrs699 in forum For Sale
    Last Post: 01-30-11, 10:18 AM
  4. TL1000R front forks - $80
    By Kitt in forum For Sale
    Last Post: 05-21-09, 09:56 AM
