Page 3 of 3 FirstFirst 123
Results 51 to 68 of 68
Suzuki Bandit won't start
  1. #51
    Windham NH
    Re: Suzuki Bandit won't start
    Its Ecto Cooler. Has to be.
    I'll need some more carb clean
    Suzuki Bandit won't start-image-jpg
    Lifer Stromper's Avatar
    Eastern Ct
    2 tanks with seafoam and you would have been golden
    still suspicious of the tank minimally pull the petcock for a look see
    Some rust buster soaking the rings for a couple of days still a good idea
    Put tires on it after over ten years they are now brittle rim protectors I suggest Bridgestone T30's
    The calculus of hate
  4. #54
    He's doing the right thing by cleaning it. I love me some Seafoam too but this job is well beyond fuel additive.
    Bingo.
    Ether, Seafoam... both are cheap, lazy, band-aid, mickey mouse, bs, temporary workarounds that don't fully solve the core problem.
    Don't dick around... get in there and fix it right.
  6. #56
    It's getting an ultrasonic clean by my local mechanic. No way can this be fully cleaned by hand.
    Took one plug out just now, and looks really good. I already bought new ones so it doesn't matter. I sprayed some WD-40 down the first hole, and some leaked out of the bolt in the front of the engine. Is this normal? I was told there was a leak somewhere, but the previous owner thought it was oil.
    Attached Thumbnails Attached Thumbnails Suzuki Bandit won't start-image-jpg
  7. #57
    That hole is a drain for the head. You've got a big cavity for the plug well, that weep hole prevents water from pooling there around the plug and eventually corroding the head from the top down. Nothing to worry about.
    Eastern Ct
    Yes, disassembling and manual cleaning could not possibly lead to problems
    Seriously check what seals the float valve , if its an O ring I would change it, ask me how I know
  9. #59
    Arlington MA 02474
    Good info on this Bandit forum, maybe you are already there
    The Suzuki Bandit forum - Index
  10. #60
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    I'd highly recommend getting a jet kit while your already into the carbs, I had a 00 bandit 1200 and from the factory they are very cold blooded( need lots of choke to start when the engines cold and until it warms up they run horrible) I did a stage 3 but I also had a gutted exhaust and modified air box/ filter. I miss how smooth and tourqey that bike was, didn't matter what gear I was in it always pulled like a tractor.
    Eastern Ct
    :iws:
  12. #62
    Just thought I would let everyone know the bike now runs. I learned a lot from everyone's posts.
    Good idea to balance those carbs if you haven't already
    Apr 2014
    Riviera beach fl
    +1
    It is extremely easy to make a synch tool, I have one that I made out of clear tubing cardboard and 2 stroke oil, it works but is very sensitive. There's also another homemade style where you use 4 bottles, which if I ever need to make another that's the style I'll make because it's just as easy and are much less sensitive.
    Congrats on getting it running, doesn't it feel great hearing it come to life for the 1st time!!!
    Simple tube loop won't work on this 4-cylinder.
    Quote Originally Posted by myzx6 View Post
    +1
    Not sure of your exact setup but installing a damper in the line will slow the response of the fluid......damper being defined as a "pill" that fits inside the existing hose. The pill has a small ID bore which effectively creates the damping affect.
    EDIT: "Vacuum restrictor" would be the appropriate terminology
  17. #67
    Apr 2014
    Riviera beach fl
    Sure it will when you add a couple tee's like I did for my 4 cylinder!!!
    Eastern Ct
    So what was the critical change that fired it up ? kill switch, kick stand, clutch lever
  1. For Sale - Motorcycles | '02 Suzuki Bandit 1200S
    By whynot in forum For Sale
    Last Post: 02-23-16, 06:36 PM
  2. For Sale - Motorcycles | 2003 Suzuki Bandit 600
    By Rossco in forum For Sale
    Last Post: 05-19-15, 07:05 PM
  3. 2004 Suzuki Bandit gs500
    By joy in forum Wanted
    Last Post: 08-08-12, 08:11 AM
  4. 2007 Suzuki Bandit 1250S
    By brianbmw in forum For Sale
    Last Post: 06-29-12, 12:42 PM
  5. Suzuki Bandit Forum
    By bergj1986 in forum General Bike Related
    Last Post: 03-11-08, 07:26 AM
