Results 1 to 25 of 29
Throttle return...
    Oct 2004
    Southeastern Taxachusetts
    Throttle return...
    I know, I am a PIA today...but can someone give me a word of advise?
    I removed my grip and controlls because the throttle does not snap back, it rolls slowly back to position and found that the throttle snaps back nicely when not on the clip-on but not so good when I put it on, indicating to me that there is residue on the clip-on or in the throttle that is hindering a smooth roll. I tried a light sandpaper on the clip-on to clean it and it seems a bit better but not great.
    Anything else I should try or just sand it again and maybe clean the inside of the throttle?
    MSF RiderCoach
    MSF Dirt Bike School Coach
    she rides like the wind
    & smells good too.
    Jun 2005
    mmmm>?
    TRy lube. Also, look for spots where the cables might be getting interferred with.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Throttle return...
    grip glue may have leaked in there....try rubbing alcohol and/or some goof-off stuff type stuff. Try to eliminate possibilities...like disconnecting the cable from teh tube and see if it is free-flowing...if it is it maybe the cable...try lubing the cable(should do this anyways)
    Giddy up! joberly's Avatar
    Apr 2004
    Raynham, MA
    Throttle return...
    I fought with this issue on my track bike all last season.... my clip on was slightly bent enough to not allow it to come back... however if yours worked before it's probably not bent? Did you try adjusting the return cable?
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    sounds like your cables not quight in the right spot
    see when it's snaping back then look close when ya put it on
    if its not what red said
    www.bostonmoto.com
    Forum Rules
    Oct 2004
    Throttle return...
    It is definately not the cable. It is friction. I will try cleaning it with alcohol.
    MSF RiderCoach
    & smells good too.
    May 2002
    Meriden CT
    just a smige off fucks every thing up
    it coud btwisting the outer just so it bindes it up look
    you work on bikes 2 what a girl
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    jaNE YA GOT THE CABLE KINKY
    DID YA LUBE IT
    www.bostonmoto.com
    Forum Rules
    Oct 2004
    Re: jaNE YA GOT THE CABLE KINKY
    Originally posted by beet
    DID YA LUBE IT
    MSF RiderCoach
    & smells good too.
    May 2002
    Meriden CT
    could also be freyed just started
    on the way out look good
    www.bostonmoto.com
    Forum Rules
    FUCK OFF Hardcore's Avatar
    Jul 2005
    norwood ma
    Throttle return...
    it's probably just the routing of the cable with too tight of a bend--try adjusting the position of the clip on or the throttle itself.
    + definately lube the bar--all the way up + all the way down, with both hands, gently twisting in opposite directions, not too fast, not too tight of a grip, ya that's it, now work it--some more lube, now you got it, a little faster, yaaa
    Jun 2005
    Throttle return...
    funny shit. It was just a matter of time before this thread went to the dark side.
    Manvile, RI
    Throttle return...
    holy crap guys..she said it is NOT the cable...the cable is disconnected from the tube..lol
    Dec 2003
    Ma
    Throttle return...
    I can't understand anything beet types.
    May 2002
    Meriden CT
    well thats why it aint snaping
    www.bostonmoto.com
    Forum Rules
    Manvile, RI
    Re: well thats why it aint snaping
    Lifer LuvDog's Avatar
    Ashland, MA
    Throttle return...
    Has the thottle return always been slow since you've had the bike or is it something new?
    I know you said you removed everything, but when you reassembled the thottle and clip on... is the grip rubbin against the bar end?
    When I've had a slow return throttle it's been either:
    cables - routing/binding
    grip - rubbing against bar end
    clip on - slightly bent
    2003 ZX7R
    1995 916
    Aug 2002
    on the couch
    Throttle return...
    Once you get it clean, graphite powder is the best stuff to use
    Jun 2005
    a quick solution or ( rig) if you don;t have the powder is to use a pencil( graphite)
    Dec 2003
    Ma
    Throttle return...
    spit on it and push
    Littering and........
    Jul 2004
    Vermont
    Throttle return...
    Originally posted by hessogood
    spit on it and push
    Is that your instructions for anal sex, or fixing a motorcycle?
    Jane, my R1 did the *exact* same thing when I changed the bar ends, and it was indeed the throttle cable. It was extremely finicky, and only snapped back if it was perfectly positioned, and the bar end was not too tight.
    Junior Member tiller's Avatar
    Oct 2002
    Rocky Hill, CT
    Throttle return...
    Jane, I had a similar problem trying to resolve a roomates bike having same issue, turns out the grip was just rubbing the bar end (shrug)
    tiller
    LRRS# 415
    www.onedownfiveup.com
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    Throttle return...
    thats what happened on my RR with stock clips ons ... it would rub the bar end
    Raymond NH
    Throttle return...
    I struggled with this same exact problem for an aggravating couple of hours with no improvement. Put on a new set of cables and it was fine. All parts worked "fine" alone but when put together, there was enough friction in total to cause a slow return. I'd order new cables.
    KB KB's Avatar
    Manchester NH
    Throttle return...
    Brent probably knocked it over in his garage and didn't tell you and now the clip on is bent.
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Hmm, how to return?
    By CEO in forum Pit Area
    Last Post: 08-19-14, 07:21 AM
  2. Replies: 59
    Last Post: 12-24-11, 12:12 PM
  3. YZ/WR 450 upon return
    By Devil1 in forum Wanted
    Last Post: 12-04-09, 01:04 AM
