Results 1 to 4 of 4
Tire gauges and compressors (two related questions)
    Jul 2008
    Waitsfield, Vermont
    Any good recommendations out there for tire gauges? I've been using a pencil-type gauge, which seems to read consistently and has a dual-direction head (i.e. two, 180-degree opposed connection points on a 45' chuck), which seems to be a pretty good roadside tool. However, I'd rather like to get my hands on a gauge that's (a) easier to read, in 1-lb or 1/2-lb increments, (b) holds the last reading until released, and (c) has a pressure relief valve so I don't have to play the "let air out for a guesstimated time, measure, repeat, go over, add air, repeat all" game. I'm thinking that means an analog gauge, not a digital one, but I'm open to either.
    I'd like to keep the price around the $30 mark if possible.
    On a related note, I'd also like to be able to top off my tires at home without rolling down to the gas station and paying 75 cents. Are there any reliable options short of buying a full-on air compressor? I'd like to avoid going that expensive, bulky, and heavy unless I'm getting substantial additional use out of the device (i.e. air tools, actually changing tires at home, that sort of thing), and I don't see that happening in the immediate future.
    thanks,
    Kevin
    Jun 2005
    Re: Tire gauges and compressors (two related questions)
    Bike pump. Seriously. Silca is probably the best.
    I used to keep one in my track trailer until some thief decided they deserved it more than me at the MotoMkt track day (extra special thanks to that asshole).
    I have an Extra Fot pump (old school) With your Tricky name on it.
    Zip Tie Alley Racing #444
    Signature edit by Tricky mike
    Junior Member axil's Avatar
    Northshore MA
    Accu-gage. It clips onto the valve so you can add or release air while the gauge is attached.
    http://www.ghmeiser.com/
  1. Tire questions.
    By lopycam in forum Pit Area
    Last Post: 02-27-09, 10:17 PM
  2. Tire Questions
    By Fitz in forum Pit Area
    Last Post: 12-20-08, 04:23 PM
  3. tire questions
    By JunoAF in forum General Bike Related
    Last Post: 08-15-08, 09:04 AM
  4. More Tire Questions...
    By Stoneman in forum Pit Area
    Last Post: 08-14-03, 03:11 PM
