Lets see if I can blurt this out so someone can understand....
My fuel tank has 3 lines coming from it (1 small & 2 big ) ....mmmkay
1 big one goes to the fuel filter then fuel pump (no problem)
1 small one runs down to the black canister (cali. emissions I think)
Which leaves me with a x-tra hose coming from the tank. The end of the hose has seemed to have broken near the end andI'm not sure where it goes.
Is it just an "overflow" "vent" line and should just be ran to the bottom of the bike?
I discovered this while going over all of the hoses on the Cali. emissions BS. When I found I had hooked up a vacum hose wrong.
Thanks to Bemused I have learned a valuable leasson about vacum hoses & there proper conection
