Results 1 to 5 of 5
Trouble starting bike when warm..
    Everybody to the limit!
    Winchester, MA
    Took the bike out for a nice long ride after work today, everything's running great...except, the last few days I've noticed, if I stop for gas or something after the bike has warmed up, it doesn't want to start again. If I twist the throttle the bike starts and surges up to 7-8k, hangs there for a second after I roll off the throttle. After that, everything's normal. The bike starts fine cold. Any ideas what could cause this?
    Northshore/Beverly, MA
    Not enuff info- Model make and year..what I'm really after..is it carbureted or FI?
    if it's FI check your coolant temp sensor...could be outta tolerance.
    Winchester, MA
    Thanks for the reply mark, bike in question is a 2000 ZX6E with just around 3.5k on the odo...carbureted...
    Sounds like the fuel levels maybe a little high in the fuel bowls.
    The fuel could be expanding and spilling down into the engine.
    Causing it to flood. By opening the throttle clears the excess fuel in the cylinders..this is why it's holding the revs up high and then dropping.
    Does it idle OK after you go thru this starting proceedure?
    Let me think about other things that can cause this...Check to make sure the carbs are mounted tightly into the manifolds, and the camps are tight too.
    Raymond NH
    The tendancy to rev high for a bit after starting, IIRC, can be caused by a vacuum leak. Does it start easier when you use a little choke (when warm)?
    I could be quite wrong, my memory sucks...
  1. Help me diagnose why my bike is not starting up
    By virtualbong in forum Bike Maintenance
    Last Post: 06-21-16, 03:21 PM
  2. Help starting carbed bike...
    By JalopySiR in forum Bike Maintenance
    Last Post: 03-30-09, 11:35 PM
  3. trouble starting
    By Punjistick in forum Bike Maintenance
    Last Post: 04-24-08, 04:56 PM
  4. Issue with bike starting
    By Billy in forum General Bike Related
    Last Post: 03-07-06, 07:29 PM
