Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
Update !!! radiator issue.. need advise
    675'r jtryz's Avatar
    May 2011
    Ashland
    Re: Update !!! radiator issue.. need advise
    some real good advice, thanks everyone. NO I am sure 30 times will not happen since there are only a few things. How was Costa Rica Bob? Have fun?
    I will go in this order from what I have gathered from forums..
    Flush system really good (couple hours and a few bucks for coolant)
    Check for leaks (just time)
    Fan (25 bucks ebay, thanks oreo)
    Radiator Cap (here this happens) $10
    Thermistat (15-20 bucks and time)
    If thats not it then we are looking at a head gasket and I will have to do my first one. I HOPE IT IS NOT THE CASE!!!!!!!!
    (from what i see on the net, allot of freakin money. lets hope a few hours of elbow grease and a few trial and errors will do it! wish me luck
    May 2011
    Ashland
    Well, I must say pretty lucky! I drained the cooant since it needed it anyways. Flushed it real good!
    Then removed the radiator and hoses to remove the fan. Since the fan was siezing up, I started with the obvious.
    Fan was jammed and barely moving, Like I said before it moves real easy, very light.
    The fan was tight so I was messin with it not assuming it was broke. And BAM, i large rock fell out of it. Somehow jammed up in the fan.
    Put it all together, and tested it a few differnt times. The fan kept kicking on with no issues.....
    Rode to work today and she is fixed.
    Cost me $1 for some distilled water and a couple of hours. The shop said 85 an hour just to diagnose it and who knows how that could have added up. Luv IT!
    So to my previous question, Can a fan make that much differnce in heat? Sure can, BIG TIME
    Lifer Dip Dungles's Avatar
    Ashland, MA
    Way to be Jeff. Love it when the fix doesn't cost you a thing.
    Shannon
    Lifer golden chicken's Avatar
    Attleboro, MA
    That bike is too pretty to be off-roading!
    Jan 2009
    Waltham
    Wirelessly posted (Infuse)
    Lol The fan didn't work with a rock in it you say?
    Glad you figured that out.
    Quote Originally Posted by jtryz View Post
    Same thing happened to us with Annalisa's first bike. Rock got stuck in the fan in a place we couldn't see. Getting stuck caused the fan's fuse to blow numerous times until I finally spun the fan and out a rock fell.
    Hopefully, you'll be all set now.
    Wirelessly posted
    Most confusing thread ever. From the description I thought the fan ran after being prodded.
    That's the language barrier for ya. I gotta hand it to ya though, Degs, you do pretty well for having English as a second language.
    Wirelessly posted
    Quote Originally Posted by OreoGaborio
    I wish a big bag of douche on you.
    May 2011
    Ashland
    Wirelessly posted
    It did work when i messed with it but for some reason it took effort. I have no idea where the rock was. I am also confused, but it's fixed...
    Wirelessly posted
    Wirelessly posted
    Good!
    I thought Doc was married?
    Lifer SprintPoser's Avatar
    Apr 2002
    Central MA
    I've had a fan on my 2000 Triumph Sprint RS disintegrate on me. I was having the exact same kind of problem that jtryz described, to a "T". Next thing I know, the fan blades and motor were no longer as one.
    If the rock damaged the fan, replace it, and I bet your problem goes in the trash can with the old fan. I'm sure I had "F.O.D." (foreign object damage) on my fan that eventually caused it to go out-of-balance and self destruct.
  1. Any road advise in my area
    By jtryz in forum Rides & Events
    Last Post: 04-22-12, 07:02 AM
  2. Need Diesel Advise
    By lrrs428 in forum Pit Area
    Last Post: 02-15-10, 08:51 AM
