Finally got the nerve to lift the front of my CBR off the ground with no one else around to help. Dry run before putting on new tires for the 10/17 track day. Put the bike on the rear stand. Put the bike up on the front stand and realized axle probably won't slide past the side of the stand. Took it off the front stand, wrapped a rag around the lower peg of the front stand, and lifted it again. Now have a couple mm clearance to slide the axle by the side plate. Anyone have a better way to do this? I tried lifting the front wheel a couple times to get more clearance, but no luck without putting the rag to get more clearance. Thanks.
