Results 1 to 11 of 11
Wheel bearings?
    rides bikes
    Nov 2014
    Wheel bearings?
    My '84 Interceptor has a god-awful howling noise coming from the front end. It comes and goes with various speeds over ~15mph, and at highway speeds it goes away altogether. It's been around for a few years, but it's getting more and more common...and louder. Any way to confirm it's a wheel bearing before I pull the wheel? No wobbles or vibrations or anything fun like that. It's just fucking annoying.
    Meriden, Ct
    Re: Wheel bearings?
    Lift the front end, spin the wheel, feel and listen...
    rides bikes
    Nov 2014
    Re: Wheel bearings?
    Yeah, I've done that. No noises and notchy-ness that I can feel. I'll just pull the wheel. I'm 99% sure it needs bearings.
    Re: Wheel bearings?
    Sometimes the weight of the wheel will hide notchy bearings . So yes pull the wheel. Since you have your tools out not a bad idea to check the rear wheel while your at it.
    Re: Wheel bearings?
    have you checked the CV joints
    Re: Wheel bearings?
    Do the bearings no matter what, but also consider the wear on the front tire. I've had tires that howl louder and louder the older they get. Might be time to change it.
    2020 BMW R1250GS Adventure Executive
    Lifer Stromper's Avatar
    Eastern Ct
    Re: Wheel bearings?
    Just get your finger in there
    If it feels notchy then they are toast
    You can get good bearings at local bearing house they are just
    OD ID and thickness with double seal
    The calculus of hate
    Re: Wheel bearings?
    If it feels notchy then they are toast.
    We still talking about bearings?
    Re: Wheel bearings?
    I have a bearing puller Kit, if needed.........
    WMC original sdog30's Avatar
    Burgy
    Re: Wheel bearings?
    How has Jimmy not had any input on this yet?
    LRRS/CCS #66
    rides bikes
    Nov 2014
    Re: Wheel bearings?
    Speedo gear! Imagine that...
  1. Wheel Bearings
    By Jim in forum Bike Maintenance
    Last Post: 08-24-11, 07:25 AM
  2. Wheel bearings... A cheaper alternative?
    Last Post: 06-07-11, 06:36 AM
  3. wheel bearings on a trailer - need help
    By Crash Dummy Denno in forum Bike Maintenance
    Last Post: 05-20-08, 08:09 AM
  4. How to install wheel bearings and oil seals
    By lucentone in forum Bike Maintenance
    Last Post: 06-30-06, 11:00 AM
