Bike is a 2010 WR250X.
Bike is used and the previous owner replaced stock lights
with smaller units, more attractive units.
When it was warm out, both blinkers worked.
In my garage, both blinkers work.
Out on the street, when it's really cold, the right blinker works.
When I hit the left blinker, the ECU indicator light comes on once and then does nothing (no lights).
Interestingly, unless I reset the switch and wait couple seconds, the right doesn't work either.
I suspected the switch, so I took it apart and cleaned the contacts leaving it connected.
As I was reassembling it, I did some continuity checks.
Intermittently, the meter reported continuity along all three legs of the switch,
when clicked it over to the left signal.
So, I think I need a new switch. Should I be suspecting anything else?
If I could figure out where the switch harness plugged in, I'd pull it and test it disconnected, but I'm too noobish.
