Results 1 to 8 of 8
ZX6 / KAWI OWNERS need help front sprocket removal
    Feb 2007
    I am wrenching on an 04 zx6 and am having trouble removing the front sprocket.
    it looks like a splined nut that has a hex too. Do I need a specialty tool or is it reverse threads?
    Bike on stand now so would appreciate any help.
    High maintenance priss
    Central MA
    Re: ZX6 / KAWI OWNERS need help front sprocket removal
    Nut should be regular thread. The lock washer and sprocket are splined.
    How are you preventing sprocket from turning? Bar thru the rear wheel? Or did you already cut the chain?
    [edit - more info]
    Here's a schematic. Make sure that lock washer (p/n 92200) is flattened. The nut will take a big breaker bar or impact to remove. Penetrating oil wouldn't hurt (PB Blaster).
    Feb 2007
    Yes bar through the wheel, I am about to ride it to a garage to try a bigger impact gun. Mine wont do it but its electric.
    Nov 2009
    Bristol County
    You try blow torching it? Heat cycle it several times with a blowtorch. Make sure you aren't cooking any rubber or thin warp-prone metal seal behind it.
    Do you have a cheater bar? If not, you might be able to make one from a jack's handle.
    nedirtriders.com
    Senior Member MFChop's Avatar
    Apr 2014
    Nashville, TN
    Hi zx6r owner here and can confirm all advice above lol
    Flatten Washer
    Put in gear
    Put board in wheel
    Unbolt Nut
    I never have an issue granted I use an impact gun
    and remember lefty lucy righty tight
    Feb 2007
    Yeah, rode it to a local garage and they busted it loose with shop air. Not easily though. Not a big fan of that design.
    Now the new sprocket is too thick it seems. The lock nut only can thread a few threads. Could this be right? There are bolt holes on the new one, is that the stock way? Small bolts?
    Central MA
    New sprocket should be similar width as the old one. You still have the old one to compare?
    [edit] Looked a the motor - you should see ~8 threads exposed on the inside of the nut. The output shaft should thread up a hair past the large and small hex portions and stop at the squared portion of the nut.
    Feb 2007
    Yes for sure its the wrong sprocket. Cant put the old one on since the chain is only long enough for a certain size.
    Wound up riding out to long island and got one BJ had laying around that fit.
    I ordered for an 04 but the bikes an 07.
    Anyway, job done. I hate when a job stalls like that the day before I leave for the track.
  1. Need to borrow/buy 1st SV front sprocket
    By tsorfas in forum Pit Area
    Last Post: 08-26-14, 12:53 PM
  2. BMW 1200 and Kawi Z1k owners
    By SVRACER01 in forum General Bike Related
    Last Post: 02-24-12, 08:41 PM
  3. Front sprocket question
    By wingerdor in forum Dirty Bastards
    Last Post: 08-12-11, 09:16 PM
  4. front sprocket nut
    By Truth in forum Bike Maintenance
    Last Post: 09-06-08, 06:28 PM
  5. Front sprocket help
    By G21forme in forum Bike Maintenance
    Last Post: 07-18-08, 01:28 PM
